'74, 2.0, 25K miles original
Spring is here and that means I will return to working on the car instead of looking at this beauty in my garage!
The clutch is a bit bucky - may refer to this as chattering. New clutch and plate, HOWEVER, I did not mill the Flywheel - clutch and plate were original so I replaced them. I swear the flywheel looked perfect so I did not have it........... - yea I know, I know.......however, if anyone has other suggestions?
As to the bucking from the throttle - I rebuilt:
Throttle system
throttle position sensor
the vacuum plenum - it is tight!
All hoses
timing - right on
plugs
valve clearance
all injectors
near everything with the exception of the wiring harness.........
the bucking is when it is in a low power between coast and starting to accelerate
Runs great everywhere else on the power band.
