Ljet Dual Relay |
Ljet Dual Relay |
Geezer914 |
May 9 2023, 04:46 PM
Geezer914 Group: Members Posts: 1,415 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I need a Bosch 0 332 514 120 dual relay for my Ljet fuel injection. Every place I look they are out of stock. CIP1 wants 160.00, and they are out of stock! Any thoughts?
May 9 2023, 04:51 PM
See if you can cross-reference it to other L-Jet cars, like the Datsun 280Z.
--DD |
May 9 2023, 05:24 PM
Post a picture?
I will go rummage in the engine room….maybe…but I think all my stuff is djet http://www.914world.com/bbs2/index.php?sho...=55291&st=0 To me, it looks like two standard relays will work. Also, check the yellow wire, maybe it got loose? |
anderssj |
May 9 2023, 06:33 PM
Dog is my copilot... Group: Members Posts: 1,656 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Sounds like the VW bus may use the same relay. If so, maybe check out the "Ratwell" article "VW Baywindow Bus - Double Relay Demystified" here:
https://www.ratwell.com/technical/DoubleRelay.html Sounds like it may be possible to build a substitute. Hope this helps! Ps. Another possible option: look at the Volvo fuel pump dual relay, used on 240s from about 1986 or so up through 1993. I'll see if I can dig up a diagram of how it works. |
wonkipop |
May 9 2023, 06:51 PM
Advanced Member Group: Members Posts: 4,297 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
pelican are listing it?
and in stock? https://www.pelicanparts.com/More_Info/0332...332-514-120-INT and at reasonable price? just to give some context. i had this relay replaced in chicago back in 89/90. cost of relay. $87.55 USD! we forget that parts were not exactly cheap back then. mind you this was parts cost from VW dealer in chicago who did the work. |
Geezer914 |
May 9 2023, 07:51 PM
When you add it to your cart it says out of stock.
May 9 2023, 08:33 PM
wonkipop |
May 9 2023, 10:40 PM
When you add it to your cart it says out of stock. ah. bummer. i'll try and do some research. will be in same boat as you if mine ever goes. guess we have to keep trying to find either the right bit or a decent substitute work around. (IMG:style_emoticons/default/beerchug.gif) |
Krieger |
May 9 2023, 10:57 PM
Advanced Member Group: Members Posts: 4,711 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I have a used one that I have had for a very long time. It worked when I took took it out of a running car I owned. I used it briefly three years ago to diagnose a similar failure in a friends car. I'd sell it for $30 plus shipping. PM me if your interested.
ClayPerrine |
May 10 2023, 07:01 AM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Sounds like the VW bus may use the same relay. If so, maybe check out the "Ratwell" article "VW Baywindow Bus - Double Relay Demystified" here: https://www.ratwell.com/technical/DoubleRelay.html Sounds like it may be possible to build a substitute. Hope this helps! Ps. Another possible option: look at the Volvo fuel pump dual relay, used on 240s from about 1986 or so up through 1993. I'll see if I can dig up a diagram of how it works. From experience, the pinout on the Bus double relay is different from the 914. I found this out the hard way. But you can move one wire and it will work. If you need the info, I can dig up the pictures when I get my home computer upgrade finished. |
Geezer914 |
May 10 2023, 07:42 AM
Clay, appreciate the help.
dr914@autoatlanta.com |
May 10 2023, 08:46 AM
914 Guru Group: Members Posts: 7,858 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
well you have not looked everywhere that is for sure.
Bosch discontinued them, we bought out the last of their stock Maybe try to take yours apart and chean and resolder the joints I need a Bosch 0 332 514 120 dual relay for my Ljet fuel injection. Every place I look they are out of stock. CIP1 wants 160.00, and they are out of stock! Any thoughts? |
jim_hoyland |
May 10 2023, 11:55 AM
Get that VIN ? Group: Members Posts: 9,297 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Are you certain the dual relay is bad ?
There is a simple method to bench test the dual-relays function with a 9v battery and a pair of short pair of connectors with alligator clips on the ends. I made a guide to do the test and can email you a copy; shoot me a pm with your email and I’ll get it to you I’d post it here, but it’s on an excel spread sheet |
Geezer914 |
May 10 2023, 05:16 PM
PM sent
Geezer914 |
May 10 2023, 05:21 PM
wonkipop |
May 11 2023, 05:39 AM
well you have not looked everywhere that is for sure. Bosch discontinued them, we bought out the last of their stock Maybe try to take yours apart and chean and resolder the joints I need a Bosch 0 332 514 120 dual relay for my Ljet fuel injection. Every place I look they are out of stock. CIP1 wants 160.00, and they are out of stock! Any thoughts? so if i did my normal rule of thumb on real estate values, (approx doubles every decade) and referring to what i paid for a dual relay in 1990. the dual relay is worth about $650 USD in 2020. yikes. (IMG:style_emoticons/default/sad.gif) which makes your listed price at around half that sort of reasonable @dr914@autoatlanta.com but its a hard hit for a little plastic double relay. but i guess that is the hit i took back in 90 in relativistic terms. or actually it was double the hit you would hit me with now. interesting to do the maths. |
Geezer914 |
May 11 2023, 08:45 AM
A special thanks to Jim Hoyland for emailing the double relay test. The relay checked out, so on to other problems. See my other post Starting Problems.
Lo-Fi Version | Time is now: 16th May 2024 - 04:32 PM |
