Seat back replacement |
bajafreaks |
May 10 2023, 01:39 PM
Member Group: Members Posts: 73 Joined: 7-February 14 From: Gardnerville, Nevada Member No.: 16,969 Region Association: Northern California |
Has anyone had experience with using the plastic 3-piece seat back replacements 914 rubber has available? my original seat back is completely gone and good used are hard to find.
Puebloswatcop |
May 10 2023, 06:00 PM
Senior Member Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
bajafreaks |
May 10 2023, 06:29 PM
Has anyone had experience with using the plastic 3-piece seat back replacements 914 rubber has available? my original seat back is completely gone and good used are hard to find. Are you talking about the 3 piece plastic back pad core? Yes...https://914rubber.com/thermal-formed-3-piece-back-pad-core-1 |
bajafreaks |
May 11 2023, 08:04 AM
Mikey914 |
May 11 2023, 08:34 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We are doing another run on these and will have them ready in about 2 weeks. If you need one right away, PM me I have one in my personal stash I can get you.
-Mark PS some folks have simply covered these in perlon and opted out on the foam and vinyl. |
Literati914 |
May 11 2023, 11:25 AM
Senior Member Group: Members Posts: 1,461 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I used this product to reupholster a backpad for another member here, about a year and a half ago. It's a good product but if you plan to upholster it as original, then the real problem is the foam. If you can re-use your original foam, then it's great. or source used foam if you can. If not, then you have to try to custom sculpt the foam.. which is what I had to do. It came out great but I'd only do it again as a labor of love (would have to charge way too much as a service to accurately sculpt out the foam for a customer). The original foam is not a simple design, luckily I had my own personal originals to go by.
bajafreaks |
May 11 2023, 03:47 PM
We are doing another run on these and will have them ready in about 2 weeks. If you need one right away, PM me I have one in my personal stash I can get you. -Mark PS some folks have simply covered these in perlon and opted out on the foam and vinyl. Thanks for the info/offer. I'm a ways out before needing it. I would definitely entertain just wrapping with no foam, although I'd be curious to see how one looks before doing it. |
bajafreaks |
May 11 2023, 03:49 PM
I used this product to reupholster a backpad for another member here, about a year and a half ago. It's a good product but if you plan to upholster it as original, then the real problem is the foam. If you can re-use your original foam, then it's great. or source used foam if you can. If not, then you have to try to custom sculpt the foam.. which is what I had to do. It came out great but I'd only do it again as a labor of love (would have to charge way too much as a service to accurately sculpt out the foam for a customer). The original foam is not a simple design, luckily I had my own personal originals to go by. . Dont have any of the original back piece, foam, or covering so it would be from scratch. I would definitely entertain as mentioned, going without the foam just curious how it looks? Thanks |
Lo-Fi Version | Time is now: 15th May 2024 - 11:14 PM |
