QUOTE(Literati914 @ May 11 2023, 10:25 AM)
I used this product to reupholster a backpad for another member here, about a year and a half ago. It's a good product but if you plan to upholster it as original, then the real problem is the foam. If you can re-use your original foam, then it's great. or source used foam if you can. If not, then you have to try to custom sculpt the foam.. which is what I had to do. It came out great but I'd only do it again as a labor of love (would have to charge way too much as a service to accurately sculpt out the foam for a customer). The original foam is not a simple design, luckily I had my own personal originals to go by.
Dont have any of the original back piece, foam, or covering so it would be from scratch. I would definitely entertain as mentioned, going without the foam just curious how it looks? Thanks
