914 with Gearbox Issues |
tonybolony |
May 11 2023, 05:04 AM
Newbie Group: Members Posts: 30 Joined: 17-September 22 From: Enland , Wes Yorkshire Member No.: 26,859 Region Association: None |
so today i got onto the gearbox , its a 1972 car and a tailshift box , the issue i have is i cant get 4/5 gears, and its not keen on giving 1st or reverse but i can get them, originally i know people say open the inspection cover and adjust the shaft , i tried this but noticed that my problem is the selector on the tailshift at the back actually doesnt want to go all the wall out for 4/5 even with persuasion at the tail shift end
914Sixer |
May 11 2023, 05:49 AM
How are your bushings? Bushing under shifter, ball at firewall and at tailshift?
tonybolony |
May 11 2023, 05:51 AM
there all good , like i say if i operate the gears from the tailshift end i actually cant get the selector shaft to come out enough for gears 4/5
Shivers |
May 11 2023, 08:54 AM
Senior Member Group: Members Posts: 2,373 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Hello. Mine is also a 72' and if all bushings are new, I will do my best to convey how it adjusts at the tail. First pardon the mess, shes been sitting. On the bracket that holds the last bushing at the tail of the transmission in place, there are two bolts that hold it on. The holes in the bracket for these fasteners are oblong. That allows you to adjust the end of the shifter rod in its cage. This picture (messy as it is) shows my adjustment on a fully shifting trans. If you can loosten (but leave snug) the two fasteners and eyeball your rod end to match this one, you'll be close. Arrow shows which way to move bracket to reach 4-5. Good luck |
tonybolony |
May 13 2023, 06:43 AM
thankyou for this
rhodyguy |
May 13 2023, 08:00 AM
Vague gear selection and hard to catch all gears? The triple rolled pin that lives above the access plate on the bottom of the trans could be the issue. Order a couple of pins and new access plate gaskets. Note the orientation of the internal components. First time I put it together incorrectly. Take apart and redo. Glad I ordered 2 pins.
Mikey914 |
May 13 2023, 08:57 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
There is adjustment in the tunnel where the shifter rod connects to the one that comes through the firewall. Id look there.
Lo-Fi Version | Time is now: 16th May 2024 - 05:29 AM |
