Screen wiper switch, I need some help with part numbers |
TonyH |
May 14 2023, 07:13 AM
Member Group: Members Posts: 50 Joined: 30-January 22 From: Normandy, France Member No.: 26,296 Region Association: France |
Good afternoon everyone,
I have a 1975 914 which I purchased about a year ago. I am going through her sorting out all the silly things that need doing. The screen wiper switch has been replaced at some time with an all electric one (it no longer uses the original air operated system). When I first bought the car she only had one speed on the wipers. I removed the wiper motor and rebuilt her so I know that is all OK. I have removed the wiper column switch and I have checked her over and is obviously faulty and needs replacing with another all electric switch which will give me two speeds and an electric washer motor option. Does anyone know of the VW part number for such a switch please? |
914Sixer |
May 14 2023, 07:48 AM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Here you go, seller in Spain. VW 111 953 519G. Has 5 pin for intermittent wipers or use for electric pump. You can also use the 6 wire option and make both pump and intermittent wipers work.
Attached thumbnail(s) |
TonyH |
May 14 2023, 08:08 AM
jim_hoyland |
May 14 2023, 08:52 AM
Get that VIN ? Group: Members Posts: 9,303 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
IIRC, the 924 Wiper switch works, plus it will connect to the intermittent relay. I have that set up currently on my ‘75
Lo-Fi Version | Time is now: 20th May 2024 - 04:39 PM |
