Padding Upper For Roll Bar |
Pierre1973 |
May 15 2023, 02:23 AM
Newbie Group: Members Posts: 33 Joined: 7-May 22 From: new caledonia Member No.: 26,525 Region Association: None |
Hello everyone,
Do you know how to disassemble the Padding Upper For Roll Bar. I unscrewed the few screws but nothing moved. An idea? In advance for all your always excellent answers. (IMG:style_emoticons/default/aktion035.gif) Attached image(s) |
Craigers17 |
May 15 2023, 02:38 AM
Senior Member Group: Members Posts: 733 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
Did you get the screws on the bottom side as well? Other than that, maybe a previous owner put some type of glue or sealant on it before they screwed it on??? I'd also double check that you got all of the screws.....to my recollection, they are in there pretty far in there and kind of hard to see....I might be overstating the obvious.
Pierre1973 |
May 15 2023, 03:06 AM
Did you get the screws on the bottom side as well? Other than that, maybe a previous owner put some type of glue or sealant on it before they screwed it on??? I'd also double check that you got all of the screws.....to my recollection, they are in there pretty far in there and kind of hard to see....I might be overstating the obvious. Ok thank you I will look tomorrow. I hope there is no glue (IMG:style_emoticons/default/wink.gif) |
bdstone914 |
May 15 2023, 07:55 AM
You need to remove the side pads too to get it out.
Pierre1973 |
May 15 2023, 02:01 PM
aturboman |
May 15 2023, 02:07 PM
Member Group: Members Posts: 135 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
Its also keyed into a slot in the pad so it needs to move forward toward the windshield first before it will drop downward.
After all of the previous tips are followed. |
porschetub |
May 16 2023, 02:29 PM
Hello everyone, Do you know how to disassemble the Padding Upper For Roll Bar. I unscrewed the few screws but nothing moved. An idea? In advance for all your always excellent answers. (IMG:style_emoticons/default/aktion035.gif) Mine had never been off and even with all the screws out it had stuck its self on . Be careful getting it off so you don't bend it,good luck. |
aharder |
May 16 2023, 07:14 PM
Advanced Member Group: Members Posts: 4,390 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
If my memory serves me right..... there are a couple of screws in the Targa Latch that have to come out.
I don't remember removing the side pads. |
Mikey914 |
May 16 2023, 07:55 PM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Actually, all are visible behind the plugs. Use a flashlight to find the head and a #1 phillips
Pierre1973 |
May 19 2023, 01:05 AM
Lo-Fi Version | Time is now: 16th May 2024 - 06:38 PM |
