Fuel line leaks..., Anyone have a diagram of how/where the fuel lines go? |
second wind |
May 17 2023, 08:50 PM
Senior Member Group: Members Posts: 855 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Hey guys.....I relocated my fuel pump to the steering rack area about 6 years ago and the fuel line I used has deteriorated and leaking badly. So I change all lines up front from the gas tank to the fuel pump and all around the front area of the car. So upon testing the front lines held nicely but back at the engine area a couple leaks have developed. As I attempt to repair it seems there are several gas lines going who knows where? I think a diagram wiuld help me quite a bit....anyone have one? Thank you very much!
gg |
ndfrigi |
May 17 2023, 10:23 PM
second wind |
May 17 2023, 11:49 PM
Thank you very much! My issue are the ones that go from the engine area down through the engine tin and then to the tunnel lines....I am lost on this and then the leaks came out of nowhere....sheesh....a gas fire can ruin your whole day!! gg PS. What is the best fire extinguisher for in front of the passenger seat? Thank you... gg |
L-Jet914 |
May 18 2023, 01:34 AM
Member Group: Members Posts: 237 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
When you replaced the fuel lines did you replace them with R30 hoses? Regular fuel injection hose will deteriorate due to the ethanol in our fuels in our state. Have you also used fuel injection hose clamps? I still need to pull my tank and all my lines to install the stainless lines.
ndfrigi |
May 18 2023, 03:24 AM
Maybe you still have the stock fuel lines in the tunnel. You have to replace it with Stainless steel lines.
Mikey914 |
May 18 2023, 04:59 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Best- onboard plumbed CO2 system with large tank. $$$$$
Bang for the buck I carry these https://914rubber.com/stelvio-brand-50-seco...re-extinguisher They are truly impressive. Attached thumbnail(s) |
second wind |
May 18 2023, 10:45 AM
Thank you all very much. I have already switched to SS lines and tgis time around I used R 30 fuel line. A few years back I replaced the fuel lines when I installed the SS lines with inferior cloth covered lines (going for the European" look.) So now I know better and R 30 is my mantra. So up front with the three port fuel pump no leaks so far. When I relocated fuel pump I installed a fuel filter up front as well as having the one in back. So somehow I am getting a leak from the lines going to the original fuel filter (removing this one)....so where do the fuel lines that go to the filter originate? I need to get a brighter work light but I haven't traced where they go yet. Also, I pulled the original fuel filter off of the factory filter holder and it was hanging free below . I started the car and there was no leaks all of a sudden....but then after a minute of running a gushing leak showed up....like something warmed up and opened up. I will continue today but I am a bit lost at this point. Any words will be appreciated.
Thank yo, gg |
JeffBowlsby |
May 18 2023, 10:59 AM
914 Wiring Harnesses Group: Members Posts: 8,507 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
second wind |
May 18 2023, 11:46 AM
Thank you Jeff very much...that is how I did mine when I relocated it. So where do the fuel lines go once they go above the engine shelf? gg |
sportlicherFahrer |
May 18 2023, 12:21 PM
Nothing to see here. Group: Members Posts: 1,079 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
Thank you Jeff very much...that is how I did mine when I relocated it. So where do the fuel lines go once they go above the engine shelf? gg The 2.0 engine fuel hose diagram is in the 1st reply to your thread. The general route is: pressure goes from the tunnel/shelf line to the #3/#4 rail, across the top of the engine to the #1/#2 rail, then to the regulator. CSV is fed from the #1/#2 rail. Return goes from the regulator, across the back of the engine/rear firewall, back down to the shelf/tunnel. |
ndfrigi |
May 18 2023, 01:17 PM
Do you have picture where you see gas leaks? I was thinking probably your fuel injector seals need replacement. They get brittle/cracked that cause gas leak.
second wind |
May 18 2023, 05:15 PM
[quote name='ndfrigi' date='May 18 2023, 12:17 PM' post='3078403']
Do you have picture where you see gas leaks? I was thinking probably your fuel injector seals need replacement. They get brittle/cracked that cause gas leak. [/quote I keep an eye on the injector seals and that is not the source. The leak seems to be coming from above the factory fuel filter holder....one second there is no leak and then gushing down the fuel line to the filter. I wonder where the line to the fuel filter is coming from. I just put a brighter light bulb in my work light so maybe that will help me? Thank you for the help. gg |
May 18 2023, 05:43 PM
The line to the filter is coming from the larger pipe through the center tunnel. The line from the filter is going to the inlet ("S" port) on the pump.
The arrow on the filter points in the direction of fuel flow, so the arrow points toward the line that goes to the fuel pump. --DD |
Lo-Fi Version | Time is now: 16th May 2024 - 02:36 PM |
