Best place for Fuel Pump |
tonybolony |
May 22 2023, 02:19 PM
Newbie Group: Members Posts: 30 Joined: 17-September 22 From: Enland , Wes Yorkshire Member No.: 26,859 Region Association: None |
hey guys , so my 914 2.0 is fitted with a pair of Twin 40 Webbers , and i was wondering where the best place is to put the fuel pump , the pump is currently located under the car behind the passenger seat, however i notice that the fuel filter doesnt fill up totally and the car does get starved , so my question is , is this pump in the wrong place ? or is the pump just not good enough , its and Edelbrock Micro Fuel Pump
tonybolony |
May 23 2023, 02:54 AM
well am going to order another pump to try first then in the same position as the last pump
technicalninja |
May 23 2023, 07:19 AM
Senior Member Group: Members Posts: 1,212 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Most fuel pumps pump fuel better than they suck fuel.
All makes moved pumps closer to the tank and then into the tank over the years. Even on the 914 the last pump set ups were below the tank. Vapor lock is far less likely to happen to fuel under pressure vs fuel under vacuum. My vote is for below the tank unless originality is critical. If you already have the pump just replacing it may solve your problem. Lots of "pump at engine" set ups ran for years without issues. Adding low pressure transfer pumps was a common modification, however. I once solved a vapor lock problem on a Dodge van by re-routing the steel feed line outside the frame rail and away from the exhaust. This was a PIA that I'd do differently now. I'd just stick a pump at the tank today... |
nditiz1 |
May 23 2023, 07:30 AM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I have this on my 6 conversion with PMO carbs. I think it is best in the biz for any car with carbs.
cb performance pump Mine is located in the frunk. Might want to move your current one first before buying another. Do you have a gauge on it to see the pressure struggling to stay ~3 psi? |
IanK |
May 23 2023, 09:49 AM
Newbie Group: Members Posts: 21 Joined: 28-April 23 From: San Diego Member No.: 27,324 Region Association: Southern California |
As others have said, up near the tank if not in the tank is best. Pushing vs pulling works better.
Geezer914 |
May 23 2023, 11:21 AM
Geezer914 Group: Members Posts: 1,409 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Rock auto Delphi pump!
May 23 2023, 12:36 PM
Since you have carbs, make sure you get a rotary pump.
Your ears will thank me ... (IMG:style_emoticons/default/popcorn[1].gif) |
914werke |
May 23 2023, 05:47 PM
"I got blisters on me fingers" Group: Members Posts: 10,058 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
tonybolony |
May 24 2023, 08:59 AM
thanks for the info , the pump was at fault and a new one has cured my problem , i will look into putting it hearer the tank in the future, as for Fuel pressure mine is ar 2 psi in the webber 40's do you recommend higher ?
also added a 123 ignition , great bit of kit and now makes my car immobilised too at the ignition which is a nice touch, anybody else use one ? and have any recommended map curves ? |
dr914@autoatlanta.com |
May 24 2023, 11:36 AM
914 Guru Group: Members Posts: 7,856 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
any isolated 3 lb pump is good enough
hey guys , so my 914 2.0 is fitted with a pair of Twin 40 Webbers , and i was wondering where the best place is to put the fuel pump , the pump is currently located under the car behind the passenger seat, however i notice that the fuel filter doesnt fill up totally and the car does get starved , so my question is , is this pump in the wrong place ? or is the pump just not good enough , its and Edelbrock Micro Fuel Pump |
930cabman |
May 24 2023, 11:40 AM
Advanced Member Group: Members Posts: 3,056 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
thanks for the info , the pump was at fault and a new one has cured my problem , i will look into putting it hearer the tank in the future, as for Fuel pressure mine is ar 2 psi in the webber 40's do you recommend higher ? also added a 123 ignition , great bit of kit and now makes my car immobilised too at the ignition which is a nice touch, anybody else use one ? and have any recommended map curves ? I have run twin Webers on several different sporting machines and always keep the fuel pressure below 2 psi. Never have starved the float bowls. |
JeffBowlsby |
May 24 2023, 02:43 PM
914 Wiring Harnesses Group: Members Posts: 8,504 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
914werke |
May 24 2023, 05:56 PM
Rich that is the cleanest front pump retro install I have ever seen. Kudos. Ever consider putting together a kit for that? Jeff, Ive been using this clamp setup for sometime, The downside is I do have to trim/grind down the area with the red arrow to allow the shield to fit properly. Ive got a bracket that is in the works that will make the fit even better & more like what you would expect OE. A kit is already planned (IMG:style_emoticons/default/smile.gif) |
Geezer914 |
May 24 2023, 06:27 PM
That is a clean set up. I want to move my pump under the steering rack so it is easier to change the fuel filter with out spilling fuel in the front trunk.
North Coast Jim |
May 24 2023, 06:37 PM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
I relocated up front under the gravel shield adjacent to the steering rack. Makes changing the fuel filter much easier. Didn't want the pump in a closed compartment like the frunk.
Just make sure the fuel line routing doesn't interfere with the steering components. Here's a pic as I just pulled all this out with the gas tank to add in a sway bar. |
windforfun |
May 26 2023, 06:00 PM
Senior Member Group: Members Posts: 1,782 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Why is it now easier to change the filter?
Lo-Fi Version | Time is now: 14th May 2024 - 05:04 PM |
