Ignition Switch Replacement, Beware Beck Arnley P/N 201-1076 |
kschulz2 |
May 26 2023, 08:46 AM
Newbie Group: Members Posts: 1 Joined: 15-August 09 From: Waukesha, WI Member No.: 10,680 Region Association: None |
I just followed Pelican Parts excellent instructions to replace my failing Ignition Switch ('74 LE, 242K miles). Replacement Switch Beck Arnley P/N 201-1076 from FLAPS DID NOT FIT, needed modification to install. Found this out, of course, when lower dash and steering column were disassembled to remove old switch.
All seems fine now, though my turn signal cancelling feature now needs some TLC. Attached File(s) Beck_Arnley_replacement_switch___doesn_t_fit_May23.pdf ( 211.16k ) Number of downloads: 206 Beck_Arnley_replacement_switch___doesn_t_fit_May23.pdf ( 211.16k ) Number of downloads: 191 |
TheCabinetmaker |
May 27 2023, 08:38 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
That one pictured is for 75\76 only. Mismarked as fitting a 74.
Lo-Fi Version | Time is now: 3rd May 2024 - 04:33 AM |
