WTB 1970 early ignition switch assembly |
GApilot |
May 26 2023, 10:21 PM
I'm new here ... Group: Members Posts: 0 Joined: 14-June 15 From: Georgetown DE Member No.: 18,852 Region Association: None |
Hi, looking for the an early ignition switch assembly for a 1970, ideally with a key. These are different than the later switch assemblies. Thanks for reading.
TheCabinetmaker |
May 27 2023, 08:28 AM
They are very scarce, but I think I have a couple. Pm coming.
914sgofast2 |
May 27 2023, 09:04 AM
Senior Member Group: Members Posts: 617 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Have you looked at a 1970 VW Bug? I think they are the same. The turn signal mechanisms are the same.
cgnj |
May 28 2023, 11:37 AM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
I'm parting a 70 ATM in Philadelphia 19124. Sent you a pm.
TheCabinetmaker |
May 30 2023, 08:13 AM
theer |
Jun 1 2023, 10:32 PM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
I might have one from a ‘70 I parted out years ago. What makes the early cylinder different?
cgnj |
Jun 2 2023, 10:04 AM
The frustration involved in removal and replacement of the ignition switch. I just did this. I'll post pics later to show how frustrating it can be.
914sgofast2 |
Jun 2 2023, 04:07 PM
I might have one from a ‘70 I parted out years ago. What makes the early cylinder different? The early switches for the 1970 model have a wiring pigtail harness soldered to the part of the ignition switch fastened to the lock cylinder. That ignition wiring pigtail has to fished thru a narrow passage in the upper steering column, and then to a connector hidden behind the dash board. On the later model cars the electrical part of the ignition switch has just several spade wiring connectors on it with the separate wiring harness already in the steering column, so you just have to connect a set of spade connectors to the rear of the switch. There is no need to fish a bunch of wires thru a passage in the column and into back of the dash board to a large connector hidden behind the dash board. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:49 PM |
