D-Jet Help - Please, Engine wont go below 3k |
Cupomeat |
May 28 2023, 12:25 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Hello 914World, While I answer a lot of questions, I rarely post, BUT I am not well versed in D-Jet. I am having an issue that seems like it should have a simple answer, but so far, I am missing it.
So I am putting back together a 2.0L recently rebuilt for a friend and once I got it all back together, and once it started, the engine won't come down below 3K RPM. (IMG:style_emoticons/default/WTF.gif) I am assuming this is some kind of Vacuum leak, maybe? It runs strong and smooth at 3K but doesn't go down with closed throttle. SO, the engine is all new and I need to break in the cam, which, while 3k is probably ok, I'd like to get it sorted before I do that 15 min of 2k RPM. I've checked all the vacuum lines and connections and see nothing wrong. I am thinking to get a smoke machine, or similar to try to see what I may have missed. I am an L-Jet Guy with little experience with D-Jet and would LOVE some pointers or suggestions. (IMG:style_emoticons/default/pray.gif) Thank you in advance and I did do some searches and haven't yet found anything like this. CupO'Meat! (the car is a 74 2.0L and I used Jeff Bowlsby's vacuum line diagram to double check) |
r_towle |
May 28 2023, 04:49 PM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I would
1) double check timing 2) remove all vacuum lines from the plenum and put tape over them 3) remove vacuum lines from throttle body and put tape over them You must leave the MPS unit connected to the plenum. Pull the hose off the plenum and do the suck test (like when we were kids trying to get a straw to stick to your tongue) If it stick, it holds a vacuum, plug it back into the plenum. If that worked, methodically connect one hose at a time, start motor each time. |
Lo-Fi Version | Time is now: 20th May 2024 - 12:18 AM |
