Is this supposed to be open? |
peteinjp |
May 31 2023, 07:43 PM
Member Group: Members Posts: 201 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None |
914werke |
May 31 2023, 07:55 PM
"I got blisters on me fingers" Group: Members Posts: 10,060 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Yes. Access to the fuel tank fittings.
Although there is also supposed to be a some trim protecting that edge that is messing. |
technicalninja |
May 31 2023, 08:08 PM
Senior Member Group: Members Posts: 1,219 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
WOW!
That is a beautiful under carriage! Wonder if the tops as nice as the bottom is? |
windforfun |
May 31 2023, 08:29 PM
Senior Member Group: Members Posts: 1,785 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
What's the "T" for? My car has only two hoses & four clamps.
May 31 2023, 08:35 PM
You are missing the bottom pan that covers that whole area
bkrantz |
May 31 2023, 08:40 PM
914 Guru Group: Members Posts: 7,763 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
peteinjp |
May 31 2023, 09:39 PM
Thanks guys. I have the bottom cover- just removed it to pull the pedal box and do some rust proofing.
Even with the bottom cover though its obviously a place where water can get in. I'm embarking on rust proofing project. Does this area rust from water ingress from not being covered? I'm thinking of printing a cover for it after I wax the inside. Pete |
May 31 2023, 10:07 PM
Thanks guys. I have the bottom cover- just removed it to pull the pedal box and do some rust proofing. Even with the bottom cover though its obviously a place where water can get in. I'm embarking on rust proofing project. Does this area rust from water ingress from not being covered? I'm thinking of printing a cover for it after I wax the inside. Next to the smaller drain tube in your picture, you'll notice a drain opening stamped into the metal which is supposed to drain any water that might get in there. (IMG:style_emoticons/default/shades.gif) |
second wind |
Jun 1 2023, 12:10 AM
Senior Member Group: Members Posts: 855 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
OMG what a great post....thank you very much!! My car was leaking gas so badly from the inferior rubber fuel lines I installed when I put my SS tunnel lines in that for the last 8 weeks I have been installing the correct R 30 9 fuel lines......so I have been looking at your picture the entire time and moved all of the connection to below the frame window.....so far it is working but what a difficult chore....nice to have someone in my same situation and working through it....I will prevail and so will you!!
gg |
Jun 1 2023, 09:48 AM
It’s an important easy access entrance for small homeless rodents.
From there they can access the paper heater tubes to allow them warm and cozy winter dwelling in the interior. |
Root_Werks |
Jun 1 2023, 09:50 AM
Village Idiot Group: Members Posts: 8,320 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
It’s an important easy access entrance for small homeless rodents. From there they can access the paper heater tubes to allow them warm and cozy winter dwelling in the interior. (IMG:style_emoticons/default/agree.gif) Would be cool if someone made a rubber or plastic plug for the hole. |
JamesM |
Jun 1 2023, 02:24 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
JamesM |
Jun 1 2023, 03:02 PM
It’s an important easy access entrance for small homeless rodents. From there they can access the paper heater tubes to allow them warm and cozy winter dwelling in the interior. (IMG:style_emoticons/default/agree.gif) Would be cool if someone made a rubber or plastic plug for the hole. Seems like a pretty easy piece to 3d print |
windforfun |
Jun 1 2023, 05:19 PM
What's hanging out of your drainage slot?
sixnotfour |
Jun 1 2023, 05:22 PM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
4 inch Soffit Vent Screen... Easy, Keep rodents out...
http://www.914world.com/bbs2/index.php?s=&...t&p=2724414 Attached image(s) |
Jun 1 2023, 08:11 PM
windforfun |
Jun 1 2023, 09:16 PM
What's hanging out of your drainage slot? Kind of a personal question. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) That's what she said. |
peteinjp |
Jun 2 2023, 05:59 PM
oh man…..
Anyway- there was a little m4 bolt hangin out of of the drain…. Thanks all- when I get the filament dried I’ll print up a little cover and post it. Pete |
930cabman |
Jun 3 2023, 05:38 AM
Advanced Member Group: Members Posts: 3,062 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
4 inch Soffit Vent Screen... Easy, Keep rodents out... http://www.914world.com/bbs2/index.php?s=&...t&p=2724414 +1, cheap, simple, easy thanks for sharing |
Freezin 914 |
Jun 3 2023, 06:22 AM
Senior Member Group: Members Posts: 856 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
4 inch Soffit Vent Screen... Easy, Keep rodents out... http://www.914world.com/bbs2/index.php?s=&...t&p=2724414 (IMG:style_emoticons/default/first.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 11:56 AM |
