peteinjp
May 31 2023, 07:43 PM
914werke
May 31 2023, 07:55 PM
Yes. Access to the fuel tank fittings.
Although there is also supposed to be a some trim protecting that edge that is messing.
technicalninja
May 31 2023, 08:08 PM
WOW!
That is a beautiful under carriage!
Wonder if the tops as nice as the bottom is?
windforfun
May 31 2023, 08:29 PM
What's the "T" for? My car has only two hoses & four clamps.
r_towle
May 31 2023, 08:35 PM
You are missing the bottom pan that covers that whole area
bkrantz
May 31 2023, 08:40 PM
QUOTE(r_towle @ May 31 2023, 08:35 PM)
Yup.
peteinjp
May 31 2023, 09:39 PM
Thanks guys. I have the bottom cover- just removed it to pull the pedal box and do some rust proofing.
Even with the bottom cover though its obviously a place where water can get in. I'm embarking on rust proofing project. Does this area rust from water ingress from not being covered? I'm thinking of printing a cover for it after I wax the inside.
Pete
May 31 2023, 10:07 PM
QUOTE(peteinjp @ May 31 2023, 08:39 PM)
Next to the smaller drain tube in your picture, you'll notice a drain opening stamped into the metal which is supposed to drain any water that might get in there.
second wind
Jun 1 2023, 12:10 AM
OMG what a great post....thank you very much!! My car was leaking gas so badly from the inferior rubber fuel lines I installed when I put my SS tunnel lines in that for the last 8 weeks I have been installing the correct R 30 9 fuel lines......so I have been looking at your picture the entire time and moved all of the connection to below the frame window.....so far it is working but what a difficult chore....nice to have someone in my same situation and working through it....I will prevail and so will you!!
gg
r_towle
Jun 1 2023, 09:48 AM
It’s an important easy access entrance for small homeless rodents.
From there they can access the paper heater tubes to allow them warm and cozy winter dwelling in the interior.
Root_Werks
Jun 1 2023, 09:50 AM
QUOTE(r_towle @ Jun 1 2023, 08:48 AM)
Would be cool if someone made a rubber or plastic plug for the hole.
JamesM
Jun 1 2023, 02:24 PM
QUOTE(windforfun @ May 31 2023, 06:29 PM)
Most likely 3 port pump relocated under the trunk
JamesM
Jun 1 2023, 03:02 PM
QUOTE(Root_Werks @ Jun 1 2023, 07:50 AM)
Seems like a pretty easy piece to 3d print
windforfun
Jun 1 2023, 05:19 PM
What's hanging out of your drainage slot?
sixnotfour
Jun 1 2023, 05:22 PM
r_towle
Jun 1 2023, 08:11 PM
QUOTE(windforfun @ Jun 1 2023, 07:19 PM)
Kind of a personal question.
windforfun
Jun 1 2023, 09:16 PM
QUOTE(r_towle @ Jun 1 2023, 07:11 PM)
That's what she said.
peteinjp
Jun 2 2023, 05:59 PM
oh man…..
Anyway- there was a little m4 bolt hangin out of of the drain….
Thanks all- when I get the filament dried I’ll print up a little cover and post it.
Pete
930cabman
Jun 3 2023, 05:38 AM
QUOTE(sixnotfour @ Jun 1 2023, 05:22 PM)
+1, cheap, simple, easy
thanks for sharing
Freezin 914
Jun 3 2023, 06:22 AM
QUOTE(sixnotfour @ Jun 1 2023, 06:22 PM)
peteinjp
Jun 4 2023, 07:03 AM
If I weren't in Japan this is the route I'd go..... shipping has gone up! For this reason every household will have a 3d printer in the future. Its the new microwave....
Pete
Van B
Jun 4 2023, 08:22 PM
Looks like a 911 aluminum cross member? Does the OE cover fit that cross member?
windforfun
Jun 5 2023, 02:32 PM
NARP74
Jun 5 2023, 03:19 PM
QUOTE(windforfun @ Jun 1 2023, 09:16 PM)
I'm still stuck on the top being better than the bottom.
peteinjp
Jun 10 2023, 12:41 AM
First draft: 100mm printed ring fits great. I’ll print it again with a full disc:
sixnotfour
Jun 10 2023, 11:01 AM
QUOTE(peteinjp @ Jun 10 2023, 12:41 AM)
peteinjp
Jun 13 2023, 07:17 PM
porschetub
Jun 14 2023, 04:01 PM
QUOTE(Van B @ Jun 5 2023, 03:22 PM)
Yes but 2 of the mounting points for the undertray have to be modified...no big deal.
And of course the support brackets off a 911 as Pete has,I made my own out of 19 x 6mm flat bar mild steel .
Van B
Jun 15 2023, 08:13 AM
QUOTE(porschetub @ Jun 14 2023, 06:01 PM)
I know I'm treading near thread hi-jacking territory so, I'll keep it simple. The novelty of this mod interests me, but I wonder about the tangible benefits? Would love to hear experiences, if anyone, including OP would be able to offer a comparison of steel tube vs Al cast beam.
v/r,
Van
peteinjp
Jun 15 2023, 08:25 AM
I know less than most as this mod was already on the car when I bought it. Aluminum obviously lighter but I did read a post stating that it flexes more than the steel. In that case I think it comes down to how hard the car will be driven. Personally on a street car I'm erring on set side of less weight.
ClayPerrine
Jun 15 2023, 08:28 AM
QUOTE(Van B @ Jun 4 2023, 09:22 PM)
You have to get the 911 cover that fits the aluminum crossmember and mounting brackets.
I have one on my big six if y'all need a picture.
peteinjp
Jun 15 2023, 08:49 AM
This is what Doug had made for my car. Aluminum sheet:
windforfun
Jun 15 2023, 09:23 AM
