Applying Cerakote to is fan/housing |
sixaddict |
Jun 7 2023, 01:16 PM
Senior Member Group: Members Posts: 801 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Looking for guidance on applying Cerakote to the fan/alternator housing and fan.since the latter needs the center to be removed and zinc plated would like to identify a source for doing that.
Can Cerakote be done DIY or does it require a vendor. Seems as though I read some of that product needs to be baked on. This is for a six engine ……had the parts vapor blasted so look pretty good except being magnesium I understand they will revert to “gray”. Appreciate any help. |
Van B |
Jun 7 2023, 05:30 PM
Senior Member Group: Members Posts: 1,585 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
They have a selection of air cured coatings that can match most of the bake on products. But you still need a gun, air, and all that good stuff.
Mikey914 |
Jun 7 2023, 05:57 PM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Wouldn't recommend baking it in an oven you eat out of. It outclassed. A good coat will feel tacky before baked.
Mikey914 |
Jun 7 2023, 05:58 PM
We use on our steering racks, as an option.
technicalninja |
Jun 7 2023, 06:10 PM
Senior Member Group: Members Posts: 1,218 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Finding a "throw away" oven big enough to do larger items is difficult. I'm watching closely for a 36" wide oven to bake Z-car cylinder heads.
This video gave me ideas for a powder coating/ceramic coating oven. It requires multiple heating elements out of normal sized trashed ovens and looks like "the best bang for the buck" IMO. After you bake a chemical coating in an oven it should not be used for food preparation again. Properly designed, the oven in the video could be taken apart and stored when not in use. https://www.youtube.com/watch?v=q7lps1KZ9i4 |
sixnotfour |
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
911S Registry guy does it all and matches factory...
Whats your level of Correct ? |
Jun 7 2023, 07:46 PM
Ben/MB911 does it a lot on 911 engine fans and shrouds he repairs. He uses the air cure.
Mikey914 |
Jun 7 2023, 08:05 PM
You can use air cure, but it’s not as durable.
mb911 |
Jun 7 2023, 08:24 PM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Van B |
Jun 7 2023, 11:10 PM
You can use air cure, but it’s not as durable. Not true. My valve covers and fan and housings with air cure are incredibly durable. Been doing this now for 10 years with not an issue. It’s all in how it is prepped and applied Any tricks to share beyond following cerakote instructions? |
mb911 |
Jun 8 2023, 05:13 AM
You can use air cure, but it’s not as durable. Not true. My valve covers and fan and housings with air cure are incredibly durable. Been doing this now for 10 years with not an issue. It’s all in how it is prepped and applied Any tricks to share beyond following cerakote instructions? Blast your parts with glass then wipe down with acetone. Spray light coats until covered and let dry. It is that simple. I just did my 928 intake and valve covers the same way and my 914 trans was done 6 years ago the same way. Pictures attached. |
mb911 |
Jun 8 2023, 05:14 AM
sixaddict |
Jun 8 2023, 12:38 PM
Ben or others——thanks for info.
I had my parts vapor blasted so nice and clean. Magnesium sand castings kind of rough . Can those be sanded to smooth a bit before applying Cerakote? If so what grit is recommended …. |
sixaddict |
Jun 8 2023, 12:41 PM
NotLance |
Jun 8 2023, 01:04 PM
Member Group: Members Posts: 69 Joined: 4-February 21 From: Northern California Member No.: 25,165 Region Association: Northern California |
Assuming Powder-coating is similar enough to applying Cerakote, I’ve had great results with a cheap harbor freight spray gun and a $40 Craigslist oven to bake it.
Only crucial part is making sure the you remove your masking without touching the powder before putting it in the oven. With powder coat you time the bake ~20min after it starts to turn shiny and it’s good to go. Cerakote likely has different baking times though. Once again I’ve only done powder coating but from what I understand the process is the same. The red control arms were done by me |
Jun 8 2023, 01:17 PM
What’s nice about cerikote is it hardly adds any dimensional thickness to the part. It’s almost like plating. Powder is thick and can cause clearance issues on some parts.
mb911 |
Jun 8 2023, 01:23 PM
Ben or others——thanks for info. I had my parts vapor blasted so nice and clean. Magnesium sand castings kind of rough . Can those be sanded to smooth a bit before applying Cerakote? If so what grit is recommended …. You actually don’t want it overly smooth. You want tooth for the paint to grab onto. My suspicion is those naysayers of air cure don’t have a lot of experience with the product. Rough prep is preferred to say 400 grit wet sand paper which would be typical of regular paints |
mb911 |
Jun 8 2023, 01:24 PM
What’s nice about cerikote is it hardly adds any dimensional thickness to the part. It’s almost like plating. Powder is thick and can cause clearance issues on some parts. Powder is really thick. I made the mistake of using powder on my suspension and in hindsight should have done cerakote |
Jun 8 2023, 02:17 PM
We use the air dry version all the time. It’s great on plastic and fiberglass. Also on metals that tend to outgas when heated.
sixaddict |
Jun 8 2023, 02:32 PM
Lo-Fi Version | Time is now: 16th May 2024 - 09:04 AM |
