What flywheel bolts to use on 2.7 with 2.0 Flywheel? |
mate914 |
Jun 11 2023, 07:33 AM
Matt Group: Members Posts: 749 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
Looks like there are two different types. So I shall ask the gurus.
Im using a 2.0 flywheel on a 2.7 engine. Do I use the 2.0 or 2.7 flywheel bolts. Thank you, Matt |
mlindner |
Jun 11 2023, 08:36 AM
Senior Member Group: Members Posts: 1,520 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Not sure about the bolts But. I learned something about installation of bolts and lock tight. You don't put it on the threads. Use old bolts and torque down, Then remove one at a time, apply lock tight with thin object into the threaded area of the crank end and then torque new bolt to spec. Same for rest, one at a time. Best, Mark
mate914 |
Jun 11 2023, 10:44 AM
Thank you. I did order new bolts for the 2.2-2.7.
Matt Not sure about the bolts But. I learned something about installation of bolts and lock tight. You don't put it on the threads. Use old bolts and torque down, Then remove one at a time, apply lock tight with thin object into the threaded area of the crank end and then torque new bolt to spec. Same for rest, one at a time. Best, Mark |
mate914 |
Jun 11 2023, 07:24 PM
Bump!
nditiz1 |
Jun 11 2023, 10:17 PM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I dont think it matters as long as you have the correct spacer. Pretty sure I used a thick spacer so the bolts were a little longer. Think I followed the 914 PET.
targa72e |
Jun 11 2023, 10:59 PM
Member Group: Members Posts: 262 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None |
I used ARP bolts specified for 2.7 engine. I am not sure of the thickness of flywheel spacer, it is what ever came up as specified for the earlier a 2.0 liter engine/Flywheel. Spacer was expensive for what it is (around $60). My engine is 2.5 (same crank as 2.4 and 2.7).
john |
porschetub |
Jun 12 2023, 05:25 PM
Looks like there are two different types. So I shall ask the gurus. Im using a 2.0 flywheel on a 2.7 engine. Do I use the 2.0 or 2.7 flywheel bolts. Thank you, Matt I remember having to shop around for these as the prices varied wildly from suppliers for the same part,while back but seem to remember some vendors were 12-$14 for the same part ended up buying for under $10/bolt. 914 bolts have the same price spread so on last build I bought from Fat Performance for a sensible price,aftermarket but sales guy mentioned they have used them for many years on race engines and no issues ...good enough for me. |
peteinjp |
Jun 13 2023, 07:09 PM
Member Group: Members Posts: 201 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None |
Is the difference between he 2.0 flywheel and the 2.7 the diameter? Rothsport used the 215mm flywheel on my 2.7 (originally a 2.4 but 6 bolt) and they are ARP 204-2802. According to the LN website they are for all 2.0 thru 3.0 engines and are considerably less expensive than OEM.
https://lnengineering.com/products/arp-pors...heel-bolts.html |
porschetub |
Jun 13 2023, 09:22 PM
Is the difference between he 2.0 flywheel and the 2.7 the diameter? Rothsport used the 215mm flywheel on my 2.7 (originally a 2.4 but 6 bolt) and they are ARP 204-2802. According to the LN website they are for all 2.0 thru 3.0 engines and are considerably less expensive than OEM. https://lnengineering.com/products/arp-pors...heel-bolts.html Great price for a top quality product,yes and cheaper than I payed for genuine,you can't go wrong with the 6 bolt kit for your application. |
peteinjp |
Jun 13 2023, 10:28 PM
It's an even better deal long term as the ARP units are reusable.
Lo-Fi Version | Time is now: 16th May 2024 - 06:54 AM |
