Trunk Release Solenoid Stopped Working, how can I get in? - tops's in there! |
Craigers17 |
Jun 12 2023, 04:44 PM
Senior Member Group: Members Posts: 738 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
The wheel part is probably overkill, but the angle of the pull is weird so I wanted it to pull smoothly. Eventually I'll shrink wrap the black taped part. I have a Porsche reflector, but no solenoid. This pull works fine, and is hidden unless you get up under the car.
ClayPerrine |
Jun 13 2023, 07:34 AM
Life's been good to me so far..... Group: Admin Posts: 15,498 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Personally, I don't like the rear reflectors. To me, they don't fit the spirit of a 914.
But if I were going to do one, I would put a tube from the latch around into the engine compartment, and put a knob on there like the one on the engine lid release. To get in the rear trunk, open the engine compartment and pull the knob for the rear trunk. Use the parts from the front trunk of a donor car and you can lock the trunk too. No fooling around with a stainless steel wire that has spent hours hanging next to the hot exhaust. (IMG:style_emoticons/default/pinch.gif) |
Shivers |
Jun 13 2023, 11:09 AM
Senior Member Group: Members Posts: 2,408 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Personally, I don't like the rear reflectors. To me, they don't fit the spirit of a 914. But if I were going to do one, I would put a tube from the latch around into the engine compartment, and put a knob on there like the one on the engine lid release. To get in the rear trunk, open the engine compartment and pull the knob for the rear trunk. Use the parts from the front trunk of a donor car and you can lock the trunk too. No fooling around with a stainless steel wire that has spent hours hanging next to the hot exhaust. (IMG:style_emoticons/default/pinch.gif) Not a fan of the reflector either, but to each his own. I do like the idea of the emergency trunk release in the engine compartment. I will eyeball that for a bit. |
Craigers17 |
Jun 13 2023, 04:24 PM
Delete
Lo-Fi Version | Time is now: 31st May 2024 - 10:32 PM |
