| peteinjp |
Jun 13 2023, 10:31 PM
Member ![]() ![]() Group: Members Posts: 212 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None
Its not a huge deal to separate the hoses but if changing the oil often it would be nice to plumb in a valve or some type of plug to reduce long term wear on the hose seal. Anyone done this? Or any other thoughts?
Pete |
peteinjp Any of you 6 guys added a valve for oil tank draining? Jun 13 2023, 10:31 PM
mlindner Hi Pete. I fabricated a 90 deg fitting for the oil... Jun 14 2023, 04:34 AM
peteinjp So you just cut the stock hose to make that correc... Jun 14 2023, 05:41 AM
mate914 Some off the 6 engines need a check valve to stop ... Jun 14 2023, 06:26 AM
fixer34
So you just cut the stock hose to make that corre... Jun 14 2023, 09:32 AM
Cairo94507 Not going to lie, I would like to add a drain valv... Jun 14 2023, 07:27 AM
914dave i have the parts to do this. My plumbing is braide... Jun 14 2023, 07:40 AM
Steve I don't have a picture handy, but I have a an-... Jun 14 2023, 07:46 AM
Biggles Definitely recommend doing this in terms of the ti... Jun 14 2023, 08:06 AM
Steve
Definitely recommend doing this in terms of the t... Jun 14 2023, 08:40 AM
Biggles
Definitely recommend doing this in terms of the ... Jun 14 2023, 10:45 AM
bahnzai
Definitely recommend doing this in terms of the t... Jun 14 2023, 06:32 PM
Biggles
[quote name='Biggles' post='3083743' date='Jun 14... Jun 15 2023, 06:28 AM
Krieger I put it on the union for the two oil lines. It wo... Jun 14 2023, 09:28 AM
fixer34
I put it on the union for the two oil lines. It w... Jun 14 2023, 09:34 AM
Root_Werks
I put it on the union for the two oil lines. It w... Jun 14 2023, 10:19 AM
johnhora :agree:
Very clever..
Nice solution...just put i... Jun 14 2023, 10:26 AM
Lucky9146 Good thread. Unfortunately I did not include a tan... Jun 14 2023, 10:43 AM
BillJ I would take two immediately. An -12 Jun 14 2023, 10:43 AM
mb911 I could do them very easily. I have a hundred 30mm... Jun 14 2023, 12:45 PM
Krieger
I could do them very easily. I have a hundred 30m... Jun 14 2023, 07:30 PM
porschetub
Its not a huge deal to separate the hoses but if ... Jun 14 2023, 01:37 PM
Steve
Its not a huge deal to separate the hoses but if... Jun 14 2023, 02:25 PM
mb911 Can you imagine how long it would take to drain th... Jun 14 2023, 03:19 PM
peteinjp
Can you imagine how long it would take to drain t... Jun 14 2023, 05:00 PM
Krieger
[quote name='mb911' post='3083809' date='Jun 15 2... Jun 14 2023, 07:15 PM
Camaro Mike I'm revaluating my setup as well. Single AN16... Jun 14 2023, 06:34 PM
Steve I'm going to try the NPT option first, since I... Jun 14 2023, 07:48 PM
flat4guy I could use a KED Jun 14 2023, 08:15 PM
BillJ Two Dumps for me. That sounds wrong somehow.... Jun 14 2023, 08:43 PM
peteinjp How hard was it to get KED clocked? In may case I ... Jun 14 2023, 10:06 PM
Krieger
How hard was it to get KED clocked? In may case I... Jun 14 2023, 10:31 PM
fixer34
How hard was it to get KED clocked? In may case I... Jun 16 2023, 06:23 PM
zoomCat
[quote name='peteinjp' post='3083891' date='Jun 1... Jun 17 2023, 06:49 PM
I haven't noticed this support on any other... Jun 17 2023, 08:49 PM
peteinjp
I haven't noticed this support on any othe... Jun 18 2023, 03:53 AM
fixer34
[quote name='mepstein' post='3084367' date='Jun 1... Jun 19 2023, 05:00 PM
targa72e I purchased these off ebay. On my car -16. I accid... Jun 14 2023, 10:22 PM
Steve
I purchased these off ebay. On my car -16. I acci... Jun 15 2023, 08:22 AM
PlaysWithCars
I'm revaluating my setup as well. Single AN1... Jun 15 2023, 12:39 AM
peteinjp
I'm revaluating my setup as well. Single AN... Jun 15 2023, 05:47 AM
gereed75 This is basically what I have except I drilled and... Jun 15 2023, 02:50 PM
peteinjp Perfect! Thanks.
Pete Jun 20 2023, 07:00 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:18 PM |
