Wiring harness snorkel, 91461201810 |
930cabman |
Jun 20 2023, 04:59 AM
Advanced Member Group: Members Posts: 3,007 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Count me in for a couple (late version)
doug_b_928 |
Jun 23 2023, 10:31 AM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
@Mikey914 Per Jeff’s post are you going to make two new versions (correct length for up to 73 and correct end for 74+)? I have your current snorkel but haven’t installed so if you make one the correct length for 73 then I’m in as well.
Yes we need to make the other version. I can see us doing that this year. My number 1 push is to complete our dash top molding. It is what is taking up most all of my time right now. I have several other items like the door pockets that are stagnated until I can break off some time to do this. I have made the drawings up and can do this pretty easily once I can break off the time to make the molds. I'll even start up a GB thread to give me some extra motivation to push this across the finish line! |
Mikey914 |
Jun 24 2023, 10:02 PM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I will be making the one with the larger top at the OEM size.
The original "early " was made slightly longer to accommodate the 6 mounts better. By all means if there are enough that want the OEM size as the tube is about an inch longer we can make them, but probably not worth retooling it. -Mark |
ThinAir |
Jun 29 2023, 09:55 PM
Best friends Group: Members Posts: 2,532 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
Pardon my ignorance, but exactly where does this go on our cars? I will be replacing g my chassis harness in the next year and I'm sure that I'll end one.
Mikey914 |
Jun 29 2023, 10:21 PM
Comes through the firewall at the bottom and pops up through the engine compartment in the front.
ndfrigi |
Jun 29 2023, 10:45 PM
ThinAir |
Jun 30 2023, 02:51 PM
That is a very helpful video! Thanks for sharing. My plan is to replace my harness next year with one of theirs.
Van B |
Nov 6 2023, 06:09 AM
Senior Member Group: Members Posts: 1,582 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
I will be making the one with the larger top at the OEM size. The original "early " was made slightly longer to accommodate the 6 mounts better. By all means if there are enough that want the OEM size as the tube is about an inch longer we can make them, but probably not worth retooling it. -Mark @Mikey914 Is this thing gonna happen? If not, then it looks like many of us won’t be able to have a replacement snorkel. |
Van B |
Nov 6 2023, 06:10 AM
914Sixer |
Nov 6 2023, 07:22 AM
914 Guru Group: Members Posts: 8,872 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I have not heard anything from Mark
Mikey914 |
Nov 6 2023, 05:36 PM
Yes this is still in the works, most likely 1st of next year, as I’ve been cleaning up projects that are still in limbo. This is one.
Will not be a huge seller, so difficult to recoup tooling and expense associated with it, so project is best finished beginning of the new fiscal year. |
Van B |
Nov 6 2023, 06:41 PM
Yes this is still in the works, most likely 1st of next year, as I’ve been cleaning up projects that are still in limbo. This is one. Will not be a huge seller, so difficult to recoup tooling and expense associated with it, so project is best finished beginning of the new fiscal year. I think you’ll be surprised. But I agree you’re not going to pay salaries with this part. Regardless, it is needed by a great many of us since the “fits all years” is not all years. |
doug_b_928 |
Nov 9 2023, 02:20 PM
The grommets fit my early 73 perfectly but the extra length looks like it will be a challenge to deal with. The late Brent Brock used what he coined a reverse foreskin method to shorten it to the correct length. I tried this without the harness inside but couldn't get it. I'm assuming presence of the wires inside will facilitate that. But you can see in the attached pic in situ how the extra length makes crinkles that will be difficult to deal with.
Mikey914 |
Nov 9 2023, 11:39 PM
We had made the 1st snorkel 1" longer for those that had 6 mounts. That's what you are seeing there.
friethmiller |
Nov 10 2023, 08:46 AM
Member Group: Members Posts: 464 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
Mark, I'll need one for my LE that I'm currently rebuilding.
ClayPerrine |
Nov 10 2023, 01:59 PM
Life's been good to me so far..... Group: Admin Posts: 15,430 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
We had made the 1st snorkel 1" longer for those that had 6 mounts. That's what you are seeing there. Why would the ones with a six mount need to be longer? (IMG:style_emoticons/default/confused24.gif) The distance from the hole for the wiring to the engine shelf hasn't changed with the addition of a six mount. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
gereed75 |
Nov 11 2023, 04:10 AM
Senior Member Group: Members Posts: 1,241 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Cut it in halves. Roll an aluminum collar to size. Cut snorkel to length. Insert collar. Shrink tube outside diameter. Voila - custom snorkel.
Van B |
Jan 17 2024, 09:26 PM
Mark, still need that snorkel for my 74… I will order 10 if it gets you to make this sooner please!
mb911 |
Jan 18 2024, 04:32 AM
914 Guru Group: Members Posts: 6,819 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Jan 18 2024, 05:12 AM
914-6 GT in waiting Group: Members Posts: 19,253 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Lo-Fi Version | Time is now: 2nd May 2024 - 07:57 PM |
