Wiring harness snorkel, 91461201810 |
mb911 |
Jan 18 2024, 02:45 PM
914 Guru Group: Members Posts: 6,819 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Mark, still need that snorkel for my 74… I will order 10 if it gets you to make this sooner please! Doesn’t Kroon have them? Also try resto design since they are making 914-4 harnesses. (IMG:style_emoticons/default/agree.gif) |
Van B |
Jan 19 2024, 12:16 AM
Senior Member Group: Members Posts: 1,582 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
No. No one has the snorkel for a 74.
mb911 |
Jan 19 2024, 05:24 AM
Van B |
Jan 19 2024, 06:45 PM
Welcome to prove me wrong, Ben… or anyone else for that matter. If you can find a parts listing that I can’t, I’ll f-ing buy you one too just for the trouble.
All I want is a harness tube that fits a 74 since “all years” is not a factual statement. |
Jan 19 2024, 08:15 PM
914-6 GT in waiting Group: Members Posts: 19,253 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Welcome to prove me wrong, Ben… or anyone else for that matter. If you can find a parts listing that I can’t, I’ll f-ing buy you one too just for the trouble. All I want is a harness tube that fits a 74 since “all years” is not a factual statement. I would just call Pete at RD on Monday. That will answer the question for sure. |
JeffBowlsby |
Jan 20 2024, 09:40 AM
914 Wiring Harnesses Group: Members Posts: 8,486 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The 74-76 double end grommet (snorkel tube) is not made, the part from 914Rubber is not technically correct for any 914/4 but can be modified to function. 914Rubber is working on them, but they have lots of irons in the fire. Be patient and work around it for now.
http://www.914world.com/bbs2/index.php?sho...&hl=snorkel Dimensions upper end x lower end x length are: 1970-73 30mm (i.d.) x 40mm (i.d.) x 230mm (upper seat to center of lower end) 1974-76 40mm (i.d.) x 40mm (i.d.) x 270mm (upper seat to center of lower end) 914Rubber 30mm (i.d.) x 40mm (i.d.) x 270mm (upper seat to center of lower end) |
mtndawg |
Jan 20 2024, 09:56 AM
Member Group: Members Posts: 413 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
I’ve used the workaround in the thread above on a ‘75 and it came out excellent!
wonkipop |
Jan 20 2024, 12:37 PM
Advanced Member Group: Members Posts: 4,255 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
https://914rubber.com/wiring-harness-snorkel-tube-1 I know this has been discussed before, but there was no thread specific to the issue and I couldn’t find the discussion. So, I wanted to post one that others can find. Bottom line, I don’t know the scope or differences among years and models, but the wiring harness snorkel sold by 914 rubber, definitely does not fit my 74. @Mikey914 any chance you’d be willing to make one with a proper size top for whatever years have this size? Or, does anyone know a source for one that will fit my 74? if i have this right the 914rubber snorkel is correct length for a 74, but the upper grommet end is too small. hole through engine shelf is larger on later cars? (i ask this as i have a 74 so would not have a clue what earlier cars are like). but if the hole is the problem. weld in a suitably sized washer to the underside of the engine shelf as a reducer. paint to match. |
mb911 |
Jan 20 2024, 01:52 PM
https://914rubber.com/wiring-harness-snorkel-tube-1 I know this has been discussed before, but there was no thread specific to the issue and I couldn’t find the discussion. So, I wanted to post one that others can find. Bottom line, I don’t know the scope or differences among years and models, but the wiring harness snorkel sold by 914 rubber, definitely does not fit my 74. @Mikey914 any chance you’d be willing to make one with a proper size top for whatever years have this size? Or, does anyone know a source for one that will fit my 74? if i have this right the 914rubber snorkel is correct length for a 74, but the upper grommet end is too small. hole through engine shelf is larger on later cars? (i ask this as i have a 74 so would not have a clue what earlier cars are like). but if the hole is the problem. weld in a suitably sized washer to the underside of the engine shelf as a reducer. paint to match. Yes I guess or find the correct grommet. Took me until after my car was painted to discover the discrepancy and mine fits like a hot dog in a hall way. I would love to make this part just don’t have the energy or time for it. |
Van B |
Jan 21 2024, 12:02 PM
https://914rubber.com/wiring-harness-snorkel-tube-1 I know this has been discussed before, but there was no thread specific to the issue and I couldn’t find the discussion. So, I wanted to post one that others can find. Bottom line, I don’t know the scope or differences among years and models, but the wiring harness snorkel sold by 914 rubber, definitely does not fit my 74. @Mikey914 any chance you’d be willing to make one with a proper size top for whatever years have this size? Or, does anyone know a source for one that will fit my 74? if i have this right the 914rubber snorkel is correct length for a 74, but the upper grommet end is too small. hole through engine shelf is larger on later cars? (i ask this as i have a 74 so would not have a clue what earlier cars are like). but if the hole is the problem. weld in a suitably sized washer to the underside of the engine shelf as a reducer. paint to match. Too long and the top flare is way too small. I’d rather pay for someone to make a batch of the right dimensions and sell them here myself to the benefit of everyone with a 74+ than arbitrarily mod the car. I’m going to start looking into injection molding companies. Lots of them can 3D print molds now that significantly reduce tooling costs for small batch parts. |
mb911 |
Jan 21 2024, 01:23 PM
https://914rubber.com/wiring-harness-snorkel-tube-1 I know this has been discussed before, but there was no thread specific to the issue and I couldn’t find the discussion. So, I wanted to post one that others can find. Bottom line, I don’t know the scope or differences among years and models, but the wiring harness snorkel sold by 914 rubber, definitely does not fit my 74. @Mikey914 any chance you’d be willing to make one with a proper size top for whatever years have this size? Or, does anyone know a source for one that will fit my 74? if i have this right the 914rubber snorkel is correct length for a 74, but the upper grommet end is too small. hole through engine shelf is larger on later cars? (i ask this as i have a 74 so would not have a clue what earlier cars are like). but if the hole is the problem. weld in a suitably sized washer to the underside of the engine shelf as a reducer. paint to match. Too long and the top flare is way too small. I’d rather pay for someone to make a batch of the right dimensions and sell them here myself to the benefit of everyone with a 74+ than arbitrarily mod the car. I’m going to start looking into injection molding companies. Lots of them can 3D print molds now that significantly reduce tooling costs for small batch parts. Van great idea. I would be happy to have them on my website if you do. |
wonkipop |
Jan 21 2024, 01:43 PM
https://914rubber.com/wiring-harness-snorkel-tube-1 I know this has been discussed before, but there was no thread specific to the issue and I couldn’t find the discussion. So, I wanted to post one that others can find. Bottom line, I don’t know the scope or differences among years and models, but the wiring harness snorkel sold by 914 rubber, definitely does not fit my 74. @Mikey914 any chance you’d be willing to make one with a proper size top for whatever years have this size? Or, does anyone know a source for one that will fit my 74? if i have this right the 914rubber snorkel is correct length for a 74, but the upper grommet end is too small. hole through engine shelf is larger on later cars? (i ask this as i have a 74 so would not have a clue what earlier cars are like). but if the hole is the problem. weld in a suitably sized washer to the underside of the engine shelf as a reducer. paint to match. Too long and the top flare is way too small. I’d rather pay for someone to make a batch of the right dimensions and sell them here myself to the benefit of everyone with a 74+ than arbitrarily mod the car. I’m going to start looking into injection molding companies. Lots of them can 3D print molds now that significantly reduce tooling costs for small batch parts. Van great idea. I would be happy to have them on my website if you do. i'll support the cause and buy one. the one on mine i can tell is aged. but of course i won't be replacing it because i won't be getting the loom out at any point. but i will put it in the box on the shelf with everything else for the car. (IMG:style_emoticons/default/beerchug.gif) |
Superhawk996 |
Jan 21 2024, 01:54 PM
914 Guru Group: Members Posts: 5,769 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I don’t even have a 74’ but will support you in your quest by buying one if you decide to go that route.
live free & drive |
Jan 21 2024, 03:53 PM
Member Group: Members Posts: 156 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None |
Formlabs recently introduced a machine that prints silicone rubber parts that are really nice (like right out of a mold). Most printed elastomeric parts previously were pretty much crap.
I've seen and held a couple of these parts - pulled on them stretched them etc and they seemed like real parts. Formlabs machines build the parts layer by layer wherein they screed material across a thin layer at a time and then cure the material layer by layer. Try this video: https://www.youtube.com/watch?v=xDoUztSoyvk&t=2s I'm not affiliated with the company, but this is the first time I've ever seen/felt printed elastomers that were anywhere close to a production part. |
JeffBowlsby |
Jan 26 2024, 12:48 PM
Attached thumbnail(s) |
Van B |
Jan 26 2024, 12:56 PM
You're the man Jeff.
wonkipop |
Jan 26 2024, 03:06 PM
gerakroo |
Apr 17 2024, 02:13 PM
Newbie Group: Members Posts: 14 Joined: 27-June 14 From: Sappemeer Member No.: 17,563 Region Association: Europe |
mb911 |
Apr 17 2024, 06:13 PM
sixaddict |
Apr 26 2024, 08:48 AM
Senior Member Group: Members Posts: 800 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Just got mine yesterday….. (IMG:style_emoticons/default/piratenanner.gif)
Lo-Fi Version | Time is now: 2nd May 2024 - 07:57 PM |
