Wiring harness snorkel, 91461201810 |
gerakroo |
May 15 2024, 08:38 AM
Newbie Group: Members Posts: 17 Joined: 27-June 14 From: Sappemeer Member No.: 17,563 Region Association: Europe |
Now available from stock, 914-4 snorkel rubber for the 914-4 1974-1976, exact reproduction of the original !
Order yours here: https://www.kroonwireharnesses.com/snorkel-rubber-914-kro23 |
Van B |
May 15 2024, 05:48 PM
Senior Member Group: Members Posts: 1,612 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
Nice!!!
Van B |
May 15 2024, 05:54 PM
Oof... Shipping is as much as the part though?
@gerakroo . Any interest in a group buy to save on sending to us here in the US? Might help you sell a few more. |
Montreal914 |
May 15 2024, 06:04 PM
Senior Member Group: Members Posts: 1,571 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
...Now if someone was to engineer one that doesn't require the removal of the harness. (IMG:style_emoticons/default/sunglasses.gif)
Using this kind of concept... (IMG:style_emoticons/default/idea.gif) |
jim_hoyland |
May 15 2024, 06:16 PM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
...Now if someone was to engineer one that doesn't require the removal of the harness. (IMG:style_emoticons/default/sunglasses.gif) Using this kind of concept... (IMG:style_emoticons/default/idea.gif) Just what I was wondering; how to get the wires into a new snorkel. Great idea ! |
mb911 |
May 15 2024, 06:48 PM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Oof... Shipping is as much as the part though? @gerakroo . Any interest in a group buy to save on sending to us here in the US? Might help you sell a few more. That would be awesome. If there was enough interest so would buy 20 of them and just resell to cover costs |
JeffBowlsby |
May 15 2024, 09:27 PM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Not that hard to install. It’s only wiring for the rear trunk lights, the relay board (r/r the plastic 14 pin housing), the battery cables and the fuel pump (r/r the connector housing). Use wire lube to pull the wires through the grommet. Easy enough.
ClayPerrine |
May 17 2024, 10:07 PM
Life's been good to me so far..... Group: Admin Posts: 15,502 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Not that hard to install. It’s only wiring for the rear trunk lights, the relay board (r/r the plastic 14 pin housing), the battery cables and the fuel pump (r/r the connector housing). Use wire lube to pull the wires through the grommet. Easy enough. (IMG:style_emoticons/default/agree.gif) I am rewiring the engine compartment on my six conversion for the MS3Pro. So while I am at it, I installed a new snorkel. Getting it in is not difficult. Just time consuming. (IMG:style_emoticons/default/slap.gif) Don't half ass it. Do it right the first time. |
gerakroo |
May 19 2024, 04:28 AM
Not that hard to install. It’s only wiring for the rear trunk lights, the relay board (r/r the plastic 14 pin housing), the battery cables and the fuel pump (r/r the connector housing). Use wire lube to pull the wires through the grommet. Easy enough. Your samples are on their way Jeff ! |
gerakroo |
May 19 2024, 04:32 AM
Oof... Shipping is as much as the part though? @gerakroo . Any interest in a group buy to save on sending to us here in the US? Might help you sell a few more. Yes, a group buy might be a good idea. I do agree that shipping is expensive for a single part, on the other hand, in general it will arrive within 2 or 3 days (from Netherlands to US) |
Lo-Fi Version | Time is now: 1st June 2024 - 09:53 AM |
