Alternator Wiring for 6 with Internal Regulator, Bringing it home now once and for all |
Robarabian |
Jun 15 2023, 09:58 PM
914 A Roo Group: Members Posts: 592 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
I am in the process of doing some work on my 6.
Old engine has the older alternator that uses the voltage reg on the relay board. Rebuilt engine has a more modern alternator, with a built in regulator. There is apparently some way to make it work, but I cant find the bulletin. More importantly, has anyone "upgraded" to the internal regulator, and what do I need to know / do to my wiring at the alt and at the board. Also, if you say, just use the old one, I can do it they both work, but it means I have to swap em... Photo is my current, older alternator. Thank you as usual. |
Lo-Fi Version | Time is now: 11th June 2024 - 02:32 AM |
