Ok, so thank you everyone for chiming in.
What I learned here was valuable:
1) 50 amp alternators and more powerful ones (70 amp plus) are available
2) If you go more powerful, you may need to check your fan housing and fan for proper depth and fitment. you can either machine down the housing or buy a new one as per the link in one of the posts.
3) They make 50 amp with internal regulators as well.
4) The wiring is fairly standard, but always check.
In the attached, final photo, the replacement alternator I got was different than pictured in the ad. It was laid out similar to the one I had, with the regulator facing down, Pos (+) on the lower left and Neg (-) on the lower right. (Click the photo for orientation correction)
The dash bulb connected to the upper left, and the upper right can be unused or capped off. I had to have the rebuilder provide me with the wiring schematic, which I will save for anyone else who needs it.
I have a spare now as my original wiring turns out to be correctly wired. But without knowledge of the rebuilder and no schematic, getting a new one was the way to go. I will take the original one to an alternator test shop at some point and positively ID the terminals.
Again, thank you to all who helped. I plan to try to get this thing buttoned up in the next 2 weeks. Cheers!
