Which jack for the jack plate?, Don't know jack |
Boothy |
Jun 22 2023, 05:50 AM
Member Group: Members Posts: 92 Joined: 17-January 19 From: Abington, MA Member No.: 22,805 Region Association: North East States |
Morning All,
I have the Tangerine Racing jack plate for engine install. I see he has one with the post and one with the hole (I know -not going there). I have the one with the post. I have an old Blackhawk jack (I played on as a kid -that's how old). The plate won't come out. My son's newer jack has the screw plate. Before I take a saw to the plate to adapt it to my son's, which of the older jacks work? I'll FB Marketplace it to try to find the right older jack. Thanks in advance! (IMG:style_emoticons/default/beer3.gif) |
VaccaRabite |
Jun 22 2023, 06:16 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
The jack plate with the hole is for engines with tuna can oil sumps.
If you can't remove your jack's plate, the CFR tool likely won't work for you. Most of them just lift out. Zach |
Geezer914 |
Jun 22 2023, 07:04 AM
Geezer914 Group: Members Posts: 1,447 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
You have 2 jacks. Put a jack under each rear donut and remove the rear wheels, slide a furniture dolly under the engine and trans. Lower the car so the engine just touches the dolly. Remove the 2 bolts holding the engine bar and the 2 rear trans bolts. raise the car and slide the engine out. Much safer than balancing on a jack plate.
rhodyguy |
Jun 22 2023, 07:57 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
The 2 floor jack method works very well. Very safe too. I put the jacks under the control arms. Loosen all of the fasteners before lowering the car. I take the exhaust off too.
Boothy |
Jun 22 2023, 08:09 AM
Thanks!
I should have specified, I'm installing. |
mgphoto |
Jun 22 2023, 09:24 AM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Morning All, I have the Tangerine Racing jack plate for engine install. I see he has one with the post and one with the hole (I know -not going there). I have the one with the post. I have an old Blackhawk jack (I played on as a kid -that's how old). The plate won't come out. My son's newer jack has the screw plate. Before I take a saw to the plate to adapt it to my son's, which of the older jacks work? I'll FB Marketplace it to try to find the right older jack. Thanks in advance! (IMG:style_emoticons/default/beer3.gif) The Tangerine jack plate has a standard saddle attachment, most jacks have a removable saddle to attach different holding devices such as the Tangerine jack plate, it fits my 30 year old Chinese Allied jack I got at Sam’s Club. |
Boothy |
Jun 22 2023, 09:32 AM
Morning All, I have the Tangerine Racing jack plate for engine install. I see he has one with the post and one with the hole (I know -not going there). I have the one with the post. I have an old Blackhawk jack (I played on as a kid -that's how old). The plate won't come out. My son's newer jack has the screw plate. Before I take a saw to the plate to adapt it to my son's, which of the older jacks work? I'll FB Marketplace it to try to find the right older jack. Thanks in advance! (IMG:style_emoticons/default/beer3.gif) The Tangerine jack plate has a standard saddle attachment, most jacks have a removable saddle to attach different holding devices such as the Tangerine jack plate, it fits my 30 year old Chinese Allied jack I got at Sam’s Club. Gotcha. Thank you! |
bzettner |
Jun 22 2023, 11:33 AM
Member Group: Members Posts: 211 Joined: 2-June 13 From: San Antonio, TX Member No.: 15,951 Region Association: Southwest Region |
Simple question, will the CFR/Tangerine engine jack plate work with a Harbor Freight 3ton, low profile jack?
(IMG:style_emoticons/default/confused24.gif) |
Osnabruck914 |
Jun 22 2023, 12:25 PM
Member Group: Members Posts: 65 Joined: 19-December 22 From: United States Member No.: 27,038 Region Association: South East States |
Simple question, will the CFR/Tangerine engine jack plate work with a Harbor Freight 3ton, low profile jack? (IMG:style_emoticons/default/confused24.gif) Yes, that's the exact combo I have and used when I dropped my engine in 2020 for a refresh. Osnabruck914 |
Lo-Fi Version | Time is now: 11th June 2024 - 06:40 AM |
