Speedo cable fell off at Transmission |
bls72 |
Jun 22 2023, 08:12 AM
Newbie Group: Members Posts: 4 Joined: 20-June 23 From: Minnesota Member No.: 27,430 Region Association: Upper MidWest |
Team! New 914 owner, and my speedo cable fell off at the transmission. I can't see if there is just a simple bolt I can get to replace it, or if there is an easy way to screw it back on? I saw a lot of posts about replacing it....but not about how to just screw it back on. Thanks!
If it's a full replacement, I'll probably just wire it up and use the GPS for a speed. 1985 1.8L |
Shivers |
Jun 22 2023, 08:17 AM
Senior Member Group: Members Posts: 2,410 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
It just slides in and screws on
dr914@autoatlanta.com |
Jun 22 2023, 08:23 AM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Look at the angle drive and see if it has come apart, it attaches to the right rear on the transmission tail cover
Team! New 914 owner, and my speedo cable fell off at the transmission. I can't see if there is just a simple bolt I can get to replace it, or if there is an easy way to screw it back on? I saw a lot of posts about replacing it....but not about how to just screw it back on. Thanks! If it's a full replacement, I'll probably just wire it up and use the GPS for a speed. 1985 1.8L |
Shivers |
Jun 22 2023, 08:47 AM
A pic would tell us a lot
rjames |
Jun 22 2023, 09:03 AM
I'm made of metal Group: Members Posts: 3,948 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Did it break in two like this?
bls72 |
Jun 22 2023, 12:35 PM
Added some pics,
I can just pull it apart where I'm pointing with the glove. It will pull right out. Almost looks like there is a bolt or something that should be holding it in? (second picture with glove pointing) Thanks for such fast replies. New to the forum and nice to see how active it is. Attached thumbnail(s) |
bls72 |
Jun 22 2023, 12:36 PM
Pointing to the back of the speedo cable. looks like it's missing a bolt here?
bls72 |
Jun 22 2023, 12:37 PM
Robert- YES< it appears to have just broke in two.
rjames |
Jun 22 2023, 12:44 PM
Robert- YES< it appears to have just broke in two. Yup, yours separated and you need a new angle drive. Simple. You're not missing a bolt. Just unbolt the half that's still attached to the transmission by loosening the nut your finger is on in the first pic. Then uninstall the other half from the cable. It will be obvious how to install the replacement when you have it in your hands. |
Shivers |
Jun 22 2023, 12:48 PM
No bolt there. Maybe a clip let go inside. Put an ad in the classified section
930cabman |
Jun 22 2023, 01:45 PM
Advanced Member Group: Members Posts: 3,130 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
If I recall correctly, there is a 8mm shoulder bolt threaded in the trans case that holds the angled speedo drive in place. Unless the drive broke into two pieces |
emerygt350 |
Jun 23 2023, 09:04 PM
Advanced Member Group: Members Posts: 2,132 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
autoAtlanta sells the elbow.
rick 918-S |
Jun 24 2023, 05:33 AM
Hey nice rack! -Celette Group: Members Posts: 20,473 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Pull this bolt. The drive will slide out. Replace it. McMark used to sell a modified one with two O-rings that sealed better. Check the classifieds for a used one or maybe Dr. Evil has some.
rjames |
Jun 24 2023, 07:50 AM
FlacaProductions |
Jun 24 2023, 09:59 AM
Senior Member Group: Members Posts: 1,607 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
rjames |
Jun 24 2023, 08:16 PM
Why do you think he needs this part? What am I missing? |
rick 918-S |
Jun 25 2023, 06:13 AM
Why do you think he needs this part? What am I missing? Oh ya Turn the big nut. Attached image(s) |
Mikey914 |
Jun 25 2023, 09:42 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Sorry,
You do not need my part. You need a new angle drive. It actually looks like yours is NOT leaking (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) |
FlacaProductions |
Jun 25 2023, 01:58 PM
Why do you think he needs this part? What am I missing? Because I'm wrong and should just stay quiet. |
Mikey914 |
Jun 26 2023, 12:35 AM
Thanks for the mention, many do need this.
Lo-Fi Version | Time is now: 2nd June 2024 - 10:53 AM |
