back window glass, question? |
hndyhrr |
Jun 26 2023, 11:44 AM
Senior Member Group: Members Posts: 556 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
The pumpkin is 70 1.7
I have taken out the back glass to get it cleaned up and better sealed. In the pic below is what I pulled off after glass removed. My question is this looks like a gasket/seal of some sort with what looks like a guitar string imbedded. Is this original to the car??? Will it be ok to use the stuff I bought from 914 rubber to reinstall it? oh and there was only one spacer block. interesting. Thanks Renee |
nivekdodge |
Jun 26 2023, 12:12 PM
Member Group: Members Posts: 251 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region |
The pumpkin is 70 1.7 I have taken out the back glass to get it cleaned up and better sealed. In the pic below is what I pulled off after glass removed. My question is this looks like a gasket/seal of some sort with what looks like a guitar string imbedded. Is this original to the car??? Will it be ok to use the stuff I bought from 914 rubber to reinstall it? oh and there was only one spacer block. interesting. 3m 8610 |
Jun 26 2023, 12:15 PM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I don’t remember all the details but I read that the wire was imbedded in the seal and would be attached to a charge to get it hot.
Root_Werks |
Jun 26 2023, 12:24 PM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I don’t remember all the details but I read that the wire was imbedded in the seal and would be attached to a charge to get it hot. That would be interesting to learn a bit more about. Replaced a few rear window seals that had the "string". Always wondered what it might have been there for. |
dr914@autoatlanta.com |
Jun 26 2023, 12:35 PM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yes it is the original buy the 1/4 inch butyl tape kit to replace it. 3M makes the "stuff"
The pumpkin is 70 1.7 I have taken out the back glass to get it cleaned up and better sealed. In the pic below is what I pulled off after glass removed. My question is this looks like a gasket/seal of some sort with what looks like a guitar string imbedded. Is this original to the car??? Will it be ok to use the stuff I bought from 914 rubber to reinstall it? oh and there was only one spacer block. interesting. |
hndyhrr |
Jun 26 2023, 05:03 PM
Next question....... The spacing block,I found only one, can I get one from a auto glass shop here in Medford,OR ?
Robarabian |
Jun 26 2023, 05:54 PM
914 A Roo Group: Members Posts: 592 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
Anyone "could" have them, they are just little pieces of rubber. AA or 914 rubber has them as well.
Also, I just did this. CLEAN, CLEAN, CLEAN. Clean is your friend. If you can do the install on a warm day, and place the butyl seal in the channel and let it get some heat, it will become even more sticky and will be easier to attach. It will still work without the heat, but I noticed it was easier to push it into place and make sure there was a good seal with minimal force, which can break the window. Get a second set of hands, the stuff is sticky. Test fit it before you do it for real. Put the ends that butt to each other at the top in a corner somewhere as water is less likely to travel upward. Once it is in, enjoy years of no water entry into the cabin from the back glass. |
Front yard mechanic |
Jun 26 2023, 06:01 PM
Senior Member Group: Members Posts: 1,172 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Save that string it looks like D string and send it to stratplayer
hndyhrr |
Jun 26 2023, 06:10 PM
Anyone "could" have them, they are just little pieces of rubber. AA or 914 rubber has them as well. Also, I just did this. CLEAN, CLEAN, CLEAN. Clean is your friend. If you can do the install on a warm day, and place the butyl seal in the channel and let it get some heat, it will become even more sticky and will be easier to attach. It will still work without the heat, but I noticed it was easier to push it into place and make sure there was a good seal with minimal force, which can break the window. Get a second set of hands, the stuff is sticky. Test fit it before you do it for real. Put the ends that butt to each other at the top in a corner somewhere as water is less likely to travel upward. Once it is in, enjoy years of no water entry into the cabin from the back glass. Heat will not be a problem suppose to top 100 in the next few days. Second seat of hands is available, They will cost me a few beers but that is fine. lol Thanks for advice. Renee |
hndyhrr |
Jun 26 2023, 06:14 PM
Anyone "could" have them, they are just little pieces of rubber. AA or 914 rubber has them as well. Also, I just did this. CLEAN, CLEAN, CLEAN. Clean is your friend. If you can do the install on a warm day, and place the butyl seal in the channel and let it get some heat, it will become even more sticky and will be easier to attach. It will still work without the heat, but I noticed it was easier to push it into place and make sure there was a good seal with minimal force, which can break the window. Get a second set of hands, the stuff is sticky. Test fit it before you do it for real. Put the ends that butt to each other at the top in a corner somewhere as water is less likely to travel upward. Once it is in, enjoy years of no water entry into the cabin from the back glass. What did you use to get the old crap off? Acetone and goof off not working like i would like. Feel like my arm is going to fall off after scrubbing with them and got half the bottom cleaned up. (IMG:style_emoticons/default/beer3.gif) |
Jun 26 2023, 06:38 PM
Try a razor blade in the glass. Also brake clean.
hndyhrr |
Jun 26 2023, 07:03 PM
Mikey914 |
Jun 26 2023, 10:03 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
1/4" is actually a little too small, but we have the setting blocks and the butyl.
$20 for all (yes both setting blocks). https://914rubber.com/reseal-kit-for-914-1 Attached thumbnail(s) |
hndyhrr |
Jun 26 2023, 10:22 PM
1/4" is actually a little too small, but we have the setting blocks and the butyl. $20 for all (yes both setting blocks). https://914rubber.com/reseal-kit-for-914-1 I bought this from you but I can not find the setting blocks. lol. I have searched high and low but no nada. Only have the the one that I found when pulling the old stuff out. |
Jun 27 2023, 12:21 AM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
IIRC, the "string" acts as a bit of a heating element embedded in the butyl, and warms it up so it sticks better.
--DD |
Shivers |
Jun 27 2023, 04:01 AM
Senior Member Group: Members Posts: 2,434 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Anyone "could" have them, they are just little pieces of rubber. AA or 914 rubber has them as well. Also, I just did this. CLEAN, CLEAN, CLEAN. Clean is your friend. If you can do the install on a warm day, and place the butyl seal in the channel and let it get some heat, it will become even more sticky and will be easier to attach. It will still work without the heat, but I noticed it was easier to push it into place and make sure there was a good seal with minimal force, which can break the window. Get a second set of hands, the stuff is sticky. Test fit it before you do it for real. Put the ends that butt to each other at the top in a corner somewhere as water is less likely to travel upward. Once it is in, enjoy years of no water entry into the cabin from the back glass. What did you use to get the old crap off? Acetone and goof off not working like i would like. Feel like my arm is going to fall off after scrubbing with them and got half the bottom cleaned up. (IMG:style_emoticons/default/beer3.gif) If you are not worried about the paint there are more aggressive solvents that work better. Otherwise maybe mineral spirits |
Mikey914 |
Jun 27 2023, 09:31 AM
1/4" is actually a little too small, but we have the setting blocks and the butyl. $20 for all (yes both setting blocks). https://914rubber.com/reseal-kit-for-914-1 I bought this from you but I can not find the setting blocks. lol. I have searched high and low but no nada. Only have the the one that I found when pulling the old stuff out. PM me your info, I can drop a set out. -Mark PS Goof off and rags you can throw away work pretty well. You will just need to wipe down with denatured alcohol before install. |
jim_hoyland |
Jun 27 2023, 01:36 PM
Get that VIN ? Group: Members Posts: 9,320 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Tip from our local glass installer: Windex is your friend. Helps when cleaning up. I used it when removing the old butyl ( and a plastic scraper) when replacing my Volvo window.
Also, the windex prevents butyl from sticking to your hands |
hndyhrr |
Jun 27 2023, 01:39 PM
1/4" is actually a little too small, but we have the setting blocks and the butyl. $20 for all (yes both setting blocks). https://914rubber.com/reseal-kit-for-914-1 I bought this from you but I can not find the setting blocks. lol. I have searched high and low but no nada. Only have the the one that I found when pulling the old stuff out. PM me your info, I can drop a set out. -Mark PS Goof off and rags you can throw away work pretty well. You will just need to wipe down with denatured alcohol before install. Thanks, I found spacer material at auto glass place here in town. |
Lo-Fi Version | Time is now: 10th June 2024 - 08:15 PM |
