QUOTE(Robarabian @ Jun 26 2023, 04:54 PM)
Anyone "could" have them, they are just little pieces of rubber. AA or 914 rubber has them as well.
Also, I just did this. CLEAN, CLEAN, CLEAN. Clean is your friend. If you can do the install on a warm day, and place the butyl seal in the channel and let it get some heat, it will become even more sticky and will be easier to attach. It will still work without the heat, but I noticed it was easier to push it into place and make sure there was a good seal with minimal force, which can break the window.
Get a second set of hands, the stuff is sticky. Test fit it before you do it for real. Put the ends that butt to each other at the top in a corner somewhere as water is less likely to travel upward.
Once it is in, enjoy years of no water entry into the cabin from the back glass.
Heat will not be a problem suppose to top 100 in the next few days. Second seat of hands is available, They will cost me a few beers but that is fine. lol
Thanks for advice.
Renee
