Play in steering shaft |
peteinjp |
Jun 27 2023, 06:25 AM
Member Group: Members Posts: 201 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None |
Have an early single stalk column and there is some play in the shaft right behind the steering wheel. Up/ down and side to side. It’s not major but a little annoying. Looking at the parts catalog it seems I’m looking at a plastic bushing. I’m sure the P.O. replaced it but thinking I maybe it can be shimmed or to print a new part.
In preparation for fixing it- what’s does this thing look like? It’s NLA according to the bird…. Pete |
dr914@autoatlanta.com |
Jun 27 2023, 08:42 AM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Have had little problem with play in the early steering shafts. We HAVE the factory bearings, but maybe check the tightness of all of the mounting bolts
Have an early single stalk column and there is some play in the shaft right behind the steering wheel. Up/ down and side to side. It’s not major but a little annoying. Looking at the parts catalog it seems I’m looking at a plastic bushing. I’m sure the P.O. replaced it but thinking I maybe it can be shimmed or to print a new part. In preparation for fixing it- what’s does this thing look like? It’s NLA according to the bird…. Pete |
peteinjp |
Jun 28 2023, 08:06 PM
Thanks. the bottom bolts are tight. Is it a bearing in the shaft or a bushing? PET describes it as a bushing....
Pete |
stownsen914 |
Jun 29 2023, 09:11 AM
Senior Member Group: Members Posts: 916 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Is it rotational play or side to side slop? If side to side, there is a plastic bushing in there if I'm recalling correctly. I may be mixing up early 911 and 914 steering columns, but I believe both have the bushing. Some replace the plastic with a metal version, a 928 part number I believe.
Lo-Fi Version | Time is now: 11th June 2024 - 03:07 AM |
