Any experience with this piston cylinder kit? |
emerygt350 |
Jun 27 2023, 01:38 PM
Advanced Member Group: Members Posts: 2,147 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
As my engine is out and I am tearing into it... I was wondering about this kit from autoAtlanta
PISTON AND CYLINDER SET (2.0 LITER, 94.0 MM, 8.1:1 COMPRESSION) S039198075 - Replacement/Accessor http://www.autoatlanta.com/results.php?par...r=914%201970-76 There is also a 96mm set but that says for 1.7 and 1.8 Not sure if that matters. |
Jack Standz |
Jun 27 2023, 02:18 PM
Member Group: Members Posts: 285 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
The 96mm set is for the 1.7 crankshaft (66mm stroke), which will give you 1911 ccs total.
Superhawk996 |
Jun 27 2023, 04:13 PM
914 Guru Group: Members Posts: 5,904 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I was just joking about 96’s being an easy swap while you had the engine out. (IMG:style_emoticons/default/poke.gif)
There are 96’s for the 2.0L to take it to 2056 but as noted above they have a different offset of the wrist pin to account for the longer stroke on the 2.0L crank. Now get back to fixing the oil leak and don’t get crazy while you’re looking at that engine sitting there so easily accessible (IMG:style_emoticons/default/happy11.gif) |
emerygt350 |
Jun 27 2023, 06:52 PM
Yeah yeah yeah... Just thinking about the rings, and if I do the rings....
And the compression jump... |
Jun 27 2023, 07:48 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
New heads….
Shivers |
Jun 27 2023, 08:53 PM
Senior Member Group: Members Posts: 2,435 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Not sure if Kolbenschmidt is still making P/C ‘s for the type 4. For a fair price I got a great product. I only ran 94’s for a thicker cylinder wall. It can get hot here, even in the winter.
Lo-Fi Version | Time is now: 11th June 2024 - 03:52 AM |
