Transmission mounting ears |
ClayPerrine |
Aug 15 2005, 11:34 AM
Life's been good to me so far..... Group: Admin Posts: 15,436 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Anyone know if the transmission mounting ears can be welded back onto the tail housing?
Cano |
Aug 15 2005, 11:37 AM
Member Group: Members Posts: 110 Joined: 29-September 04 From: Goshen, KY Member No.: 2,854 Region Association: None |
Isn't that magnesium? Not sure, but I would think that would just catch on fire if welding is attempted.
Crazyhippy |
Aug 15 2005, 11:52 AM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
I have seen it done.
Held up w/ a v-8 in front of it too. |
URY914 |
Aug 15 2005, 12:01 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,384 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
How did it break off? |
Cap'n Krusty |
Aug 15 2005, 01:37 PM
Yes, they can. People weld mag all the time. Seen a ton of them over the years. Might be more cost effective to simply replace the cover, however. The Cap'n |
dlee1967 |
Aug 15 2005, 01:43 PM
V8Lurker Group: Members Posts: 540 Joined: 20-February 03 From: Splendora, TX Member No.: 327 Region Association: None |
Clay, why bother? There are plenty of spares around. DLee
JFJ914 |
Aug 15 2005, 03:45 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
Mine have been welded by a DPO.
Aaron Cox |
Aug 15 2005, 03:47 PM
plenty o tailshift ones running around... even with a sideshifter....you can use the functionless tail hsifter housing.,.,,,,
seen it on a brumos 914 race car (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
hmeeder |
Aug 15 2005, 04:56 PM
Dante's Sportscar Group: Members Posts: 352 Joined: 21-November 04 From: San Diego, CA Member No.: 3,154 |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
Someone here has a spare, I'm sure. Hell, I have a spare from a tailshifter you can have for the price of shipping, as long as you can live with the tailshift shaft dangling there like a dead dick. |
Series9 |
Aug 15 2005, 05:22 PM
My welding reference book says magnesium can be TIG welded, but that the welding should be accomplished outside due to the risk of fire. Filings and magnesium dust should be kept away from the area to help prevent the part from lighting up.
As we all know, magnesium supports its own combustion, so if it catches fire, stand back and let it burn. Send it to me. I'll give it a shot. |
mightyohm |
Aug 15 2005, 05:32 PM
My car has a welded ear. It has held up fine (so far).
Mueller |
Aug 15 2005, 05:40 PM
make sure you preheat it with your oxy-act. touch first......actually you can use gas weld it as well.....
outside with the proper exting. agent is a good idea (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Joe Bob |
Aug 15 2005, 05:51 PM
Us married guys thank you for that visual.... (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) |
ChrisFoley |
Aug 15 2005, 05:57 PM
I am Tangerine Racing Group: Members Posts: 7,922 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I welded a crack in one ear on my freshly rebuilt race box just a month ago.
It requires pure magnesium filler wire. Don't gas weld it, TIG it. The technique is similar to welding aluminum but a little more difficult, using AC. Grind a groove with a carbide mounted in a die grinder. Use a stainless wire brush to keep the weld area clean. While welding it may fume a bit of white powdery stuff. This is normal. Be carefull not to overheat the weld zone. The puddle will have no strength and drop a snot which may catch fire. The casting has a lot of porosity which will end up inside the weld. You have to grind it out after welding and reweld in order to have any decent strength. This may be required a couple of times. |
Wild 6 |
Aug 15 2005, 07:24 PM
See you at the next autocross. Group: Members Posts: 212 Joined: 16-November 04 From: Phoenix, AZ Member No.: 3,128 |
I broke both of the ears off of my 915 gearbox. I took it to a Porsche shop who then took it to a boat shop for welding. It turns out that the boat shops weld aluminum and magnesium all the time. It's held up ever since.
Andy |
ClayPerrine |
Aug 15 2005, 09:09 PM
I actually didn't break one. I got a tailhousing with a broken ear. I was just wondering if it was hard to fix. I don't know anyone who can weld magnesium, so I thought I would ask.
Red-Beard |
Aug 15 2005, 09:28 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
Find a type I shop. They will know where to get mag welded.
ChrisFoley |
Aug 16 2005, 06:24 AM
If you can't find anyone local, ship it to me and I'll weld it for you. (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif)
Katmanken |
Aug 16 2005, 02:44 PM
Both ears of mine were broken and welded. I probably don't want to know what happened that made that repair necessary ..... (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif)
Also had to have a bellhousing crack welded later. I used a local VW Bug shop. Ask if they do MAG. Ken |
Lo-Fi Version | Time is now: 4th May 2024 - 07:34 PM |
