> WOT: ARRGGHHH, i hate fixing someone elses code!, F%^$SH*&@@@
post Aug 15 2005, 07:33 PM
Resident German
this was supposed to be a simple stripped down BASE64 decoder done in java.
i don't (can't) use a lot of standard libraries because this App will be run on PDAs and java enabled cellphones, so SIZE does matter.
no problem, i get one of my contractors the BASE64 specs and some sample implementations ...
he's been fighting with this for 3 days now so i get his sourcefile and have a look at it this morning.
looks OK at first glance, but when you run it, it sporadically spits out wrong bytevalues while some decode just fine.
wtf?
so i spend all day going through his code (which is not that much) and i just can't figure out what's wrong.
then finally, about 15 minutes ago it dawns on me, have a look at this:
bReturn2[nn+2] = (byte)(iRes % 0xFF);
bReturn2[nn+1] = (byte)((iRes >> 8) % 0xFF);
bReturn2[nn+0] = (byte)((iRes >> 16) % 0xFF);
bReturn2 is a byte array, iRes a integer, the purpose is to roll the lower 3 bytes of the integer into 3 sequential fields in the byte array.
i had been staring at this for 6 hours and couldn't figure out what was wrong.
all the while it was right in front of me, plain sight, right there ... (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
can you find the error?
(IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Andy
PS: did i mention that i HATE going through someone else code?
SpecialK
post Aug 15 2005, 08:02 PM
aircraft surgeon
I have NFI, but I'd guess you're missing a parenthesis in the first line........but then again....I have NFI. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Get your broken off allen wrench out?
Midtowner
post Aug 15 2005, 08:15 PM
Ooooo!
Sounds all Japanese to me! (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Joe Bob
post Aug 15 2005, 08:27 PM
Or ya got extra ones....parenthesis that is....
Foxman
post Aug 15 2005, 08:29 PM
What are you calculating the remainder of? Are you dividing iRes and 0XFF somewhere else? It is hard to say without seeing the rest of the function.
johnmhudson111
QUOTE (Buzzard1 @ Aug 15 2005, 09:02 PM)
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Just a WAG since I have no coding ability, just an analyst by nature and that seems to be the missing pattern.
post Aug 15 2005, 08:32 PM
Resident German
QUOTE (johnmhudson111 @ Aug 15 2005, 07:29 PM)
nope, nothing missing, syntax is just fine, compiles and runs without an error ...
(IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy
post Aug 15 2005, 08:35 PM
Resident German
QUOTE (Foxman @ Aug 15 2005, 07:29 PM)
this takes a 4 byte integer and zeros out all bits except the lowest 8 (0xff) and then stores those 8 bit in an byte-array.
1st line has no shift to get 1st byte
2nd line has 8 bit shift to get 2nd byte
3rd line has 16 bit shift to get 3rd byte
that all is correct, but he still managed to f&%$ it up ...
(IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) Andy
johnmhudson111
post Aug 15 2005, 08:36 PM
QUOTE (SirAndy @ Aug 15 2005, 09:32 PM)
bReturn2[nn+2] = (byte)((iRes >> 4) % 0xFF);
Nother WAG, I give up after this one (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif)
jonwatts
post Aug 15 2005, 08:37 PM
no rules, just wrong
I would have used the '&' operator instead of the '%' operator, but that's just me.
r_towle
post Aug 15 2005, 08:58 PM
Custom Member
QUOTE (SirAndy @ Aug 15 2005, 08:33 PM)
wtf?
bReturn2[nn+0] = (byte)(iRes % 0xFF);
bReturn2[nn+2] = (byte)((iRes >> 16) % 0xFF);
post Aug 15 2005, 09:07 PM
Resident German
QUOTE (jonwatts @ Aug 15 2005, 07:37 PM)
we've got a winner! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
he used the "%" operator which is MODULO instead of "&" which is bitwise AND ...
took me 6 friggin hours to find that one!
(IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Andy
here's the correct code snippet:
bReturn2[nn+2] = (byte)(iRes & 0xFF);
bReturn2[nn+1] = (byte)((iRes >> 8) & 0xFF);
bReturn2[nn+0] = (byte)((iRes >> 16) & 0xFF);
jonwatts
Dumb question. Is your input base10 or base16? It doesn't matter to the compiler but it makes a difference to us humans.
ematulac
post Aug 15 2005, 09:08 PM
914 addict
edit: nevermind ... modulus looked strange to me there, but it didn't register.
jonwatts
post Aug 15 2005, 09:09 PM
WOW, and I am such a suck-ass programmer too, but I do have to live in byte-stream land on a daily basis so maybe that helps.
I'd like to thank the Academy, my agent, and Andy for the beautiful 944 CV's, axles, and powder coated trailing arms (or do I just win an attaboy?).
post Aug 15 2005, 09:10 PM
Resident German
QUOTE (ematulac @ Aug 15 2005, 08:08 PM)
He's storing the bytes in the wrong order in the array.
nope, java integer is reverse byte order, so that part was correct ...
jon nailed it, see post above!
(IMG:http://www.914world.com/bbs2/html/emoticons/type.gif) Andy
Foxman
post Aug 15 2005, 09:12 PM
damn, I never thought about the input.
- Lo-Fi Version Time is now: 20th November 2026 - 03:56 AM
