Full Version: WOT: ARRGGHHH, i hate fixing someone elses code!
this was supposed to be a simple stripped down BASE64 decoder done in java.
i don't (can't) use a lot of standard libraries because this App will be run on PDAs and java enabled cellphones, so SIZE does matter.
no problem, i get one of my contractors the BASE64 specs and some sample implementations ...
he's been fighting with this for 3 days now so i get his sourcefile and have a look at it this morning.
looks OK at first glance, but when you run it, it sporadically spits out wrong bytevalues while some decode just fine.
wtf?
so i spend all day going through his code (which is not that much) and i just can't figure out what's wrong.
then finally, about 15 minutes ago it dawns on me, have a look at this:
bReturn2[nn+2] = (byte)(iRes % 0xFF);
bReturn2[nn+1] = (byte)((iRes >> 8) % 0xFF);
bReturn2[nn+0] = (byte)((iRes >> 16) % 0xFF);
bReturn2 is a byte array, iRes a integer, the purpose is to roll the lower 3 bytes of the integer into 3 sequential fields in the byte array.
i had been staring at this for 6 hours and couldn't figure out what was wrong.
all the while it was right in front of me, plain sight, right there ... headbang.gif
can you find the error?
idea.gif Andy
PS: did i mention that i HATE going through someone else code?
SpecialK
I have NFI, but I'd guess you're missing a parenthesis in the first line........but then again....I have NFI. confused24.gif
Get your broken off allen wrench out?
Midtowner
Joe Bob
Or ya got extra ones....parenthesis that is....
Foxman
What are you calculating the remainder of? Are you dividing iRes and 0XFF somewhere else? It is hard to say without seeing the rest of the function.
johnmhudson111
QUOTE (Buzzard1 @ Aug 15 2005, 09:02 PM)
agree.gif Just a WAG since I have no coding ability, just an analyst by nature and that seems to be the missing pattern.
QUOTE (johnmhudson111 @ Aug 15 2005, 07:29 PM)
nope, nothing missing, syntax is just fine, compiles and runs without an error ...
wink.gif Andy
QUOTE (Foxman @ Aug 15 2005, 07:29 PM)
this takes a 4 byte integer and zeros out all bits except the lowest 8 (0xff) and then stores those 8 bit in an byte-array.
1st line has no shift to get 1st byte
2nd line has 8 bit shift to get 2nd byte
3rd line has 16 bit shift to get 3rd byte
that all is correct, but he still managed to f&%$ it up ...
dry.gif Andy
johnmhudson111
QUOTE (SirAndy @ Aug 15 2005, 09:32 PM)
wink.gif Andy
bReturn2[nn+2] = (byte)((iRes >> 4) % 0xFF);
jonwatts
I would have used the '&' operator instead of the '%' operator, but that's just me.
r_towle
QUOTE (SirAndy @ Aug 15 2005, 08:33 PM)
wtf?
idea.gif Andy
bReturn2[nn+0] = (byte)(iRes % 0xFF);
bReturn2[nn+2] = (byte)((iRes >> 16) % 0xFF);
QUOTE (jonwatts @ Aug 15 2005, 07:37 PM)
he used the "%" operator which is MODULO instead of "&" which is bitwise AND ...
took me 6 friggin hours to find that one!
headbang.gif Andy
here's the correct code snippet:
bReturn2[nn+2] = (byte)(iRes & 0xFF);
bReturn2[nn+1] = (byte)((iRes >> 8) & 0xFF);
bReturn2[nn+0] = (byte)((iRes >> 16) & 0xFF);
jonwatts
Dumb question. Is your input base10 or base16? It doesn't matter to the compiler but it makes a difference to us humans.
ematulac
edit: nevermind ... modulus looked strange to me there, but it didn't register.
jonwatts
WOW, and I am such a suck-ass programmer too, but I do have to live in byte-stream land on a daily basis so maybe that helps.
I'd like to thank the Academy, my agent, and Andy for the beautiful 944 CV's, axles, and powder coated trailing arms (or do I just win an attaboy?).
QUOTE (ematulac @ Aug 15 2005, 08:08 PM)
He's storing the bytes in the wrong order in the array.
nope, java integer is reverse byte order, so that part was correct ...
jon nailed it, see post above!
type.gif Andy
Foxman
damn, I never thought about the input.
