fuel regulator recommendations pls, 2.2l six w/return line |
Retroracer |
Jul 15 2023, 09:06 AM
Senior Member Group: Members Posts: 612 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
Putting this out to the hive mind.
CONTEXT: Am in process of converting my -6 from a deadhead regulator (no return line) to a return system. I have a front mounted pump running at around 9psi and need a return style regulator (with 8mm plumbing) that can get me 3 -5 PSI mounted near the engine. Am struggling to find a suitable off-the-shelf solution. Any recommendations very welcome, - Tony |
dr914@autoatlanta.com |
Jul 15 2023, 09:33 AM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
use the factory six pump, no regulator needed
Putting this out to the hive mind. CONTEXT: Am in process of converting my -6 from a deadhead regulator (no return line) to a return system. I have a front mounted pump running at around 9psi and need a return style regulator (with 8mm plumbing) that can get me 3 -5 PSI mounted near the engine. Am struggling to find a suitable off-the-shelf solution. Any recommendations very welcome, - Tony |
brant |
Jul 15 2023, 10:00 AM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
The most common I’ve seen used is the PMO
And it has provisions to mount a fuel pressure gauge also Make certain any pressure gauge you use is only mounted to a chassis point and not the engine I’ve seen motor fires personally (a friend I helped put it out) when the gauge was mounted to a carb and vibration cracked the brass fitting |
nditiz1 |
Jul 15 2023, 10:06 AM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I second, using a PMO.
slivel |
Jul 15 2023, 10:31 AM
Old car....... older driver Group: Members Posts: 509 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
I've been running this Holley bypass reg for years. The fuel delivery system for my 3.4 l six with Weber 46's consists of a Holley blue pump, bypass reg set at 12 psi, and second reg at the engine set to 3.5 psi. The return line dumps right back into the fuel cell so that the fuel and pump don't get too hot.
burton73 |
Jul 15 2023, 11:33 AM
burton73 Group: Members Posts: 3,526 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Retroracer |
Jul 15 2023, 11:54 AM
Thanks for responses, all.
New Porsche original 911T pump lists at over $800; so no. Don't need the originality, so the PMO solution looks good; but those seem to be "out of stock" on the usual sites. If anyone has a used one (Bob?) they are willing to sell, pls PM. Thx, - Tony |
Lo-Fi Version | Time is now: 19th May 2024 - 11:57 PM |
