Splitting case |
Splitting case |
barkamatic |
Jul 16 2023, 05:09 PM
Newbie Group: Members Posts: 36 Joined: 6-March 23 From: Colorado Member No.: 27,211 Region Association: None |
I have spent the last hour cringing at YouTube videos watching guys gouge the **** out of sealing surfaces with a screwdriver trying to split a case. I have split dozens of vw 1200 cases but this is my first two litre. I don't want to screw it up. All fasteners are removed. Do I bang or pry?
Jul 16 2023, 05:12 PM
I have spent the last hour cringing at YouTube videos watching guys gouge the **** out of sealing surfaces with a screwdriver trying to split a case. I have split dozens of vw 1200 cases but this is my first two litre. I don't want to screw it up. All fasteners are removed. Do I bang or pry? Small bolt on front near center? Small bolt in rear near RMS? I’m a bit of a farmer on this step I cut a 2X4 and use that to hit the case. Or a piece of oak I never hit the case with a metal anything |
barkamatic |
Jul 16 2023, 05:16 PM
I have spent the last hour cringing at YouTube videos watching guys gouge the **** out of sealing surfaces with a screwdriver trying to split a case. I have split dozens of vw 1200 cases but this is my first two litre. I don't want to screw it up. All fasteners are removed. Do I bang or pry? Small bolt on front near center? Small bolt in rear near RMS? I’m a bit of a farmer on this step I cut a 2X4 and use that to hit the case. Or a piece of oak I never hit the case with a metal anything All bolts removed. Where do I hit? |
burton73 |
Jul 16 2023, 05:21 PM
burton73 Group: Members Posts: 3,525 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I have spent the last hour cringing at YouTube videos watching guys gouge the **** out of sealing surfaces with a screwdriver trying to split a case. I have split dozens of vw 1200 cases but this is my first two litre. I don't want to screw it up. All fasteners are removed. Do I bang or pry? Small bolt on front near center? Small bolt in rear near RMS? I’m a bit of a farmer on this step I cut a 2X4 and use that to hit the case. Or a piece of oak I never hit the case with a metal anything Just did this one on last Friday. Tap, Tap tap easy and double Ck on every bolt. We printed out from world pictures of each and every nut and bolt. Ck one more time Best Bob B |
burton73 |
Jul 16 2023, 05:23 PM
iankarr |
Jul 16 2023, 05:24 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
There’s a tool which spreads the case apart using the oil pump bore. That…or get a pack of wood shims and gently tap them in to wedge open the case. Resist the urge to grab a putty knife or screwdriver (IMG:style_emoticons/default/smile.gif)
barkamatic |
Jul 16 2023, 05:25 PM
I have spent the last hour cringing at YouTube videos watching guys gouge the **** out of sealing surfaces with a screwdriver trying to split a case. I have split dozens of vw 1200 cases but this is my first two litre. I don't want to screw it up. All fasteners are removed. Do I bang or pry? Small bolt on front near center? Small bolt in rear near RMS? I’m a bit of a farmer on this step I cut a 2X4 and use that to hit the case. Or a piece of oak I never hit the case with a metal anything Just did this one on last Friday. Tap, Tap tap easy and double Ck on every bolt. We printed out from world pictures of each and every nut and bolt. Ck one more time Best Bob B This will probably be the last engine rebuild I will do. Don't want to mess it up. Thanks for the response. |
Jul 16 2023, 05:40 PM
I have spent the last hour cringing at YouTube videos watching guys gouge the **** out of sealing surfaces with a screwdriver trying to split a case. I have split dozens of vw 1200 cases but this is my first two litre. I don't want to screw it up. All fasteners are removed. Do I bang or pry? Small bolt on front near center? Small bolt in rear near RMS? I’m a bit of a farmer on this step I cut a 2X4 and use that to hit the case. Or a piece of oak I never hit the case with a metal anything All bolts removed. Where do I hit? Both ends Oil fill, vent area There is also a knub on the other end Using wood allows for a bit more forceful swing |
930cabman |
Jul 16 2023, 05:42 PM
Advanced Member Group: Members Posts: 3,066 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Listen for a hollow sound
cassmcentee |
Jul 16 2023, 09:12 PM
Member Group: Members Posts: 180 Joined: 12-July 18 From: Squaw Valley, CA Member No.: 22,304 Region Association: Central California |
Start with this: https://www.jbugs.com/product/16-9601.html
I just split my 2.0 case last week. Tighten the nut till that part of the case begins to separate. Then I used plastic pry tools (Harbor Freight) like these: https://www.harborfreight.com/nylon-pry-bar...iece-63594.html Like wedges, I hammered them into the gap on opposite side of the case. The case will scar the plastic tools, not the other way 'round! I had to hammer them in pretty hard to get the adhesive to break. They didn't leave a single scratch! (IMG:style_emoticons/default/biggrin.gif) |
technicalninja |
Jul 16 2023, 09:28 PM
Senior Member Group: Members Posts: 1,236 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
I used the same case splitter as mentioned above.
Only way to do it in my book. I put a piece of "gorilla" tape on each of the shoes to protect the oil pump bore. Worked super easy. I did not need any wedges at all but the plastic wedges are the only ones to use if you need them. |
cassmcentee |
Jul 16 2023, 11:04 PM
barkamatic |
Jul 17 2023, 12:06 PM
Start with this: https://www.jbugs.com/product/16-9601.html I just split my 2.0 case last week. Tighten the nut till that part of the case begins to separate. Then I used plastic pry tools (Harbor Freight) like these: https://www.harborfreight.com/nylon-pry-bar...iece-63594.html Like wedges, I hammered them into the gap on opposite side of the case. The case will scar the plastic tools, not the other way 'round! I had to hammer them in pretty hard to get the adhesive to break. They didn't leave a single scratch! (IMG:style_emoticons/default/biggrin.gif) You called that one right. Easy with the proper tool and I did waste a couple Harbor Freight door panel pry tools. Attached thumbnail(s) |
barkamatic |
Jul 17 2023, 12:10 PM
targa72e |
Jul 17 2023, 11:08 PM
Member Group: Members Posts: 262 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None |
I use a turnbuckle (available at local hardware store) like this.
Put it over studs and front and back studs on the motor. I apply a little pressure and if it doesn't separate, double check for missed nut (IMG:style_emoticons/default/smile.gif) . If all nuts are undone then a little tap with hammer usually gets things moving Can work back and forth from front to back, top to bottom until apart. Note that I am usually splitting 911 cases. john |
Lo-Fi Version | Time is now: 19th May 2024 - 02:42 PM |
