slapshot |
Member ![]() ![]() Group: Members Posts: 144 Joined: 11-June 23 From: Utah Member No.: 27,409 Region Association: Rocky Mountains ![]() ![]() |
I have a 1975 914 2.0 with Weber Dual 40 DNCF 12. When I do a compression test with the carbs, filters off and full throttle I only get 65 PSI. If I remove the carbs I get 102. I know 102 is still low but what could be wrong with my carbs limiting airflow? I've only had the car for about 7 months and stilling learning.
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,169 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
I have a 1975 914 2.0 with Weber Dual 40 DNCF 12. When I do a compression test with the carbs, filters off and full throttle I only get 65 PSI. If I remove the carbs I get 102. I know 102 is still low but what could be wrong with my carbs limiting airflow? I've only had the car for about 7 months and stilling learning. (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) |
Jack Standz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 513 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None ![]() ![]() |
Gotta think it's the testing procedures.
Fully charged battery, remove all spark plugs, etc., etc. Here's just one video on the subject: https://m.youtube.com/watch?v=mOQGz-GQxBI Best wishes. |
slapshot |
That's a good video. I've watched it before but it was good to watch again. I am planning on getting a leak down tester soon.
The battery I used wasn't the best but it was cranking and I was getting consistent #'s between cylinders. I had all plugs out. I will do a video the next time I test it. Maybe that will show what's up. |
slapshot |
I must have had something wrong when I first did this. Second time the compression was the same. Maybe it was the battery. Anyhow, all is good.
Lo-Fi Version | Time is now: 14th July 2025 - 08:22 PM |
