Weber 40 IDF Spanish, TOP plate repair? |
rfinegan |
Jul 23 2023, 10:58 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
rfinegan |
Jul 23 2023, 11:00 AM
top view of part
nditiz1 |
Jul 23 2023, 01:05 PM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I think I have a spare one you can have. Mine don't have those extra copper tubes. I don't think I have ever seen those in all my webers (6 or 7 sets). Is that a jet doctor kit?
Superhawk996 |
Jul 23 2023, 01:09 PM
914 Guru Group: Members Posts: 5,826 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Die cast always dicey to fix. There is a very thin temperature zone between hot enough to flow a brazing rod and actually melting it into a blob.
Check out Aladdin 3 in 1 rod. It’s my go to for zinc / aluminium die cast. Due to the critical nature of the float pivot and the long thin standoff that will be tough to control the heat, I’d say get a new top. |
rfinegan |
Jul 23 2023, 02:26 PM
Yep , that s my DYI jet doctor in my 2056 thread...
if ya have a top..Im in..let me know I ll pm you I think I have a spare one you can have. Mine don't have those extra copper tubes. I don't think I have ever seen those in all my webers (6 or 7 sets). Is that a jet doctor kit? |
rfinegan |
Jul 26 2023, 11:15 AM
The carb top from Nick is in my dunk it tank and will be back in service in no time..Than you @nditiz1
Im happy to return a favor if needed..your a great member and one of the good ones in the World Best Regards -Robert |
Jul 27 2023, 06:55 AM
What do those copper tubes do?
Superhawk996 |
Jul 27 2023, 07:08 AM
@nditiz1 . (IMG:style_emoticons/default/first.gif)
nditiz1 |
Jul 27 2023, 07:47 AM
Thanks for the kind words.
The copper tubes pull air higher up. Without them any dirt that collect on the top plate is sucked right into the idle jet. |
rfinegan |
Jul 27 2023, 08:02 AM
MikeK |
Jul 27 2023, 09:14 AM
Member Group: Members Posts: 108 Joined: 15-June 23 From: 80906 Member No.: 27,418 Region Association: Rocky Mountains |
That’s great you got a new top. I’ve repaired that problem in the past by using a piece of stainless sheet metal. Cut it to the width of the cast boss. Put a little bend in one end to receive the float pivot, like a sickle shape. Cut a narrow kerf at the base of where the cast piece snapped and insert the stainless into the kerf until the ‘sickle’ is at the same height as the cast float pin holder. Mine was a pretty tight, press fit, but I could see how a tiny dab of JB would be an additional insurance.
MikeK |
Jul 27 2023, 09:24 AM
rfinegan |
Jul 27 2023, 03:42 PM
Jul 27 2023, 04:56 PM
poor mans idle jet Doctors (also viable from CB)https://www.cbperformance.com/product-p/7557.htm Same reason the main set stack was extended too The jet stack on my 44 Italians (early) have the flush with the top main jet stacks Learn every day here. I never thought there might be a solution for this problem. I just remove/clean/replace |
Lo-Fi Version | Time is now: 18th May 2024 - 03:06 AM |
