Heating system, Can't turn it off |
erwindv |
Jul 26 2023, 06:27 AM
Newbie Group: Members Posts: 46 Joined: 17-June 16 From: Belgium Member No.: 20,119 Region Association: Europe |
Heating in winter is ok but when you can't turn it off in summer it's al little bit too much.
Any idea where to look for the problem? |
DRPHIL914 |
Jul 26 2023, 06:51 AM
cable could be too tight so its holding the flappers open, check the tension on those cables that run to each flapper box , i usually remove the tubes and put caps on both ends so no air is flowing from the HE to the tubes up front .
Phil |
Jul 26 2023, 07:02 AM
Oddly a normal spray paint can cover fits perfectly on the heater tube end sticking out of the longitudinal, and it keeps out rodents.
Cairo94507 |
Jul 26 2023, 07:05 AM
Michael Group: Members Posts: 9,759 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
It is also possible someone shoved the flappers on more than necessary and the flap is conflicting with the heater tube. That happened to me; I loosed the flapper valve and pulled it back about 1/4" and the flapper opened and closed as it should.
Disconnect the cables to each side at the flapper lever and operate the flapper by hand from under the car to see if it is opening and closing completely. (IMG:style_emoticons/default/beerchug.gif) |
Jul 26 2023, 07:13 AM
Was someone making flapper box rebuild kits?
rhodyguy |
Jul 26 2023, 08:55 AM
Control wire too tight? Set the operating length with the handle down (fully closed position). The gaskets might be spent or missing.
TheCabinetmaker |
Jul 26 2023, 09:27 AM
Lo-Fi Version | Time is now: 16th May 2024 - 09:38 PM |
