TPS, Clean or replace? |
meares |
Aug 16 2005, 08:55 AM
Member Group: Members Posts: 403 Joined: 23-March 05 From: Atlanta Member No.: 3,800 |
if i should clean it....do i clean it with Brakleen or fuel inj. cleaner or spray carb cleaner?
phantom914 |
Aug 16 2005, 08:59 AM
non-914-owner non-club member Group: Benefactors Posts: 1,013 Joined: 24-February 04 From: Covina,CA(North ofWest Covina) Member No.: 1,708 |
I used contact cleaner/lube. If a track is worn into the contacts (most likely), you can bend the arm a little to one side so that the tip wipes along a path a little to the side of the original path. Just make sure that the flat of the arm stays parallel to the surface of the contact board so that only the ball of the tip makes contact. Sorry I don't have pictures, but it will probably make sense once you have the thing apart. Oh, did I forget to mention that you will need to take the TPS apart?
Andrew |
meares |
Aug 16 2005, 09:30 AM
contact cleaner/lube is found at FLAPS?.......... and just kind of twist the contact so it rides on the edge? is that right?
phantom914 |
Aug 16 2005, 09:40 AM
An electronics store would have contact cleaner. It's hard to explain the "adjustment", but I think it will be more clear once you have it apart.
Andrew |
meares |
Aug 16 2005, 09:50 AM
Thank you (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
redshift |
Aug 16 2005, 09:52 AM
BMartin914 |
Aug 16 2005, 01:23 PM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
Yea, you can buy stabilant 22a for $70 a crack (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) . Or you can do what I did and go with the $2.49 can of electrical cleaner at carquest.
Lo-Fi Version | Time is now: 4th May 2024 - 03:02 PM |
