meares
Aug 16 2005, 08:55 AM
if i should clean it....do i clean it with Brakleen or fuel inj. cleaner or spray carb cleaner?
phantom914
Aug 16 2005, 08:59 AM
I used contact cleaner/lube. If a track is worn into the contacts (most likely), you can bend the arm a little to one side so that the tip wipes along a path a little to the side of the original path. Just make sure that the flat of the arm stays parallel to the surface of the contact board so that only the ball of the tip makes contact. Sorry I don't have pictures, but it will probably make sense once you have the thing apart. Oh, did I forget to mention that you will need to take the TPS apart?
Andrew
meares
Aug 16 2005, 09:30 AM
contact cleaner/lube is found at FLAPS?.......... and just kind of twist the contact so it rides on the edge? is that right?
phantom914
Aug 16 2005, 09:40 AM
An electronics store would have contact cleaner. It's hard to explain the "adjustment", but I think it will be more clear once you have it apart.
Andrew
meares
Aug 16 2005, 09:50 AM
Thank you
redshift
Aug 16 2005, 09:52 AM
I use a q-tip.
M
BMartin914
Aug 16 2005, 01:23 PM
Yea, you can buy stabilant 22a for $70 a crack
. Or you can do what I did and go with the $2.49 can of electrical cleaner at carquest.
