Quick Question.... |
MikeM |
Aug 2 2023, 01:56 PM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...can someone please tell me the size of the nuts for the clutch adjusting mechanism at the end of the cable. Can't seem to find something that works.
Thanks in advance!! Mike |
930cabman |
Aug 2 2023, 02:00 PM
Advanced Member Group: Members Posts: 3,061 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
MikeM |
Aug 2 2023, 02:03 PM
Hi all...can someone please tell me the size of the nuts for the clutch adjusting mechanism at the end of the cable. Can't seem to find something that works. Thanks in advance!! Mike 11MM Is it a strange thread pitch or something? |
mgphoto |
Aug 2 2023, 02:17 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Hi all...can someone please tell me the size of the nuts for the clutch adjusting mechanism at the end of the cable. Can't seem to find something that works. Thanks in advance!! Mike 11MM Is it a strange thread pitch or something? Only 2 pitches on a 914 fine at 1.0 and course at 1.5. |
Steve |
Aug 2 2023, 02:25 PM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
11mm wrench. 7mmx1.0 nut
MikeM |
Aug 2 2023, 02:27 PM
technicalninja |
Aug 2 2023, 02:57 PM
Senior Member Group: Members Posts: 1,216 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
7/16 us standard wrench/socket will fit that size nicely.
Aug 2 2023, 05:08 PM
M7 is a bit of an oddball size nut on our cars. Almost everything is M6 (taking a 10mm wrench) or M8 (taking a 13mm wrench). The clutch adjustment nuts are about the only ones I can think of off the top of my head that are M7 (and take an 11mm wrench).
--DD |
MikeM |
Aug 2 2023, 05:31 PM
M7 is a bit of an oddball size nut on our cars. Almost everything is M6 (taking a 10mm wrench) or M8 (taking a 13mm wrench). The clutch adjustment nuts are about the only ones I can think of off the top of my head that are M7 (and take an 11mm wrench). --DD You are exactly right Dave!! Hard to find. They have 2 of them at Bolt Supply in my city. I'll take them!!! |
Steve |
Aug 2 2023, 05:34 PM
M7 is a bit of an oddball size nut on our cars. Almost everything is M6 (taking a 10mm wrench) or M8 (taking a 13mm wrench). The clutch adjustment nuts are about the only ones I can think of off the top of my head that are M7 (and take an 11mm wrench). --DD You are exactly right Dave!! Hard to find. They have 2 of them at Bolt Supply in my city. I'll take them!!! My ACE Hardware has them. |
Aug 2 2023, 05:52 PM
My 1974 motorcycles use M7 bolts to hold the gas tank. It was a bit of a challenge to find replacements.
Aug 2 2023, 06:05 PM
M7 is a bit of an oddball size nut on our cars. Almost everything is M6 (taking a 10mm wrench) or M8 (taking a 13mm wrench). The clutch adjustment nuts are about the only ones I can think of off the top of my head that are M7 (and take an 11mm wrench). Aren't the torsion bar adjusters 11mm also? (IMG:style_emoticons/default/idea.gif) I could be wrong though, it's been a long time since i had to fiddle with those. (IMG:style_emoticons/default/driving.gif) |
ClayPerrine |
Aug 3 2023, 04:45 AM
M7 is a bit of an oddball size nut on our cars. Almost everything is M6 (taking a 10mm wrench) or M8 (taking a 13mm wrench). The clutch adjustment nuts are about the only ones I can think of off the top of my head that are M7 (and take an 11mm wrench). Aren't the torsion bar adjusters 11mm also? (IMG:style_emoticons/default/idea.gif) I could be wrong though, it's been a long time since i had to fiddle with those. (IMG:style_emoticons/default/driving.gif) Yes... On a /4 they are 11mm. On a factory /6, IIRC, they are a 6mm cap head screw. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:44 PM |
