Brake reservoir to master lines, rigid lines |
ghettojet |
Aug 4 2023, 11:20 AM
Newbie Group: Members Posts: 6 Joined: 20-March 22 From: queens new york Member No.: 26,409 Region Association: North East States |
Hi,
i know there are tons of posts about this subject but I'd just like to offer my experience. My car was a total engine out and apart stripped body even wiring harness out basket case when i got it luckily for free. . . . Anyway I'm down to doing the brakes on the car.Master is shot so i get new one,it had the steel washers in it under the grommets.Fluid resevoir was cracked so found a new one.So there were also the remnants of some sort of hard plastic lines crumbling and deteriorated that went from reservoir to master cyl.So those are NLA as far as I could tell but I did find at one vender short 90 degree steel feeder tubes that press into grommets on master C.Then i get a length of brake fluid rated rubber hose,red actually not blue from another vendor and at this point figure i should be good to go. Wrong. seat feeder tubes,bleed master,bleed brakes.awesome! Until morning puddle of brake fluid on floor. Pull master check everything.Appears to be bad sealing point where feeder tubes are seating on the nifty little washers in the master.Weird. re-install very carefully and i noticed because there was some fluid in my bench bled MC and that the slight side load or actually pulling up on the feeder tubes is breaking the seal from feeder to steel washer this seal was already starting to weep fluid The MC isn't even in position yet. I've decided to make my own feeder tubes that I'm going to bend slightly so they follow the firewall through the pass through hole without the weird 90 degree bend that is causing the leak. Once my new feeders are through the firewall I'll continue with red flexible brake fluid line to the the reservoir. I'll post if it works |
Lo-Fi Version | Time is now: 17th May 2024 - 04:07 PM |
