Gas pedal support rust., Anyone make replacement steel? |
jaredmcginness |
Aug 7 2023, 07:03 AM
... Group: Members Posts: 502 Joined: 12-June 19 From: Baltimore Member No.: 23,209 Region Association: MidAtlantic Region |
Hey guys,
I have a car in that is missing almost all the steel here. Are there any options to get this metal? I'd think a cut off, but that would be near impossible to cut out! Looks like RD does not make this area. I am missing all of the metal up to the brake master cylinder on the drivers side. Passenger side is so-so, fabricate-able. The heaps of sound deadening applied was a total moisture trap and hid the rust really well. Hours into a save, (you can see I am already test fitting up new floors) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1691413436.1.jpg) |
Front yard mechanic |
Aug 7 2023, 07:17 AM
Senior Member Group: Members Posts: 1,163 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
That area is difficult to repair first step would involve removing everything that is in the way brake master cylinder , lines ,wiring ,tunnel linkage and all that crappy insulation that is helping the rust. Putting the car upside down makes it easier to fix the problems . This part will have to be cut from another car or fabricated from scratch (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif)
Superhawk996 |
Aug 7 2023, 07:25 AM
914 Guru Group: Members Posts: 5,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Been there - done that. Details in my rustoration thread - around page 18. Link in my signature box.
I obtained donor metal. Was still a tricky area to repair. Someone recently posted that Dansk was going to be making a complete front to rear floor pan with this section of previously NLA metal. Sure it won’t be cheap but it would be a big help with something like this. |
jaredmcginness |
Aug 7 2023, 07:29 AM
Thanks for the great insight fellas. I will speak with the owner and see what he would like to do. Meantime I will check out your thread Superhawk.
I am happy to fabricate the section, but its clearly a very difficult one, and I don't want to risk getting the geometry off. At some point it might be better to swap everything to a better tub, instead of replacing the entire bottom 3" of this car. |
VaccaRabite |
Aug 7 2023, 07:35 AM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Joe's car? Or is this a different one?
Zach |
jaredmcginness |
Aug 7 2023, 07:51 AM
dr914@autoatlanta.com |
Aug 7 2023, 08:21 AM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yes you can buy "the hump" we have them
Hey guys, I have a car in that is missing almost all the steel here. Are there any options to get this metal? I'd think a cut off, but that would be near impossible to cut out! Looks like RD does not make this area. I am missing all of the metal up to the brake master cylinder on the drivers side. Passenger side is so-so, fabricate-able. The heaps of sound deadening applied was a total moisture trap and hid the rust really well. Hours into a save, (you can see I am already test fitting up new floors) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1691413436.1.jpg) |
76-914 |
Aug 7 2023, 08:22 AM
There is a '76 listed here that the seller is asking if anyone needs parts off it.
930cabman |
Aug 7 2023, 10:04 AM
Advanced Member Group: Members Posts: 3,064 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
yep, that's an ugly repair. I would search for a donor, even then take your time with the alignment.
East coaster |
Aug 7 2023, 04:24 PM
Senior Member Group: Members Posts: 1,673 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
Lo-Fi Version | Time is now: 17th May 2024 - 01:50 PM |
