Contracted 914 fever— is this the car to cure it?, What do you think of this ‘73 914 2.0 on Bat— pass or play? |
Superhawk996 |
Mar 18 2024, 02:30 PM
914 Guru Group: Members Posts: 5,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Allen head will be fine.
Triple square head can withstand more torque when it is clean and proper tool is used. Having said that, people have been swapping out for Allen head since the 914 was practically new. Americans don’t like fancy tools like Torx, triple square, Ribe, etc. (IMG:style_emoticons/default/stirthepot.gif) : Back in the day, they pitched a fit over just having to buy metric tools evilgrin: |
trylon |
Mar 21 2024, 07:11 AM
Member Group: Members Posts: 204 Joined: 9-August 23 From: Connecticut Member No.: 27,514 Region Association: North East States |
trylon |
Mar 21 2024, 07:12 AM
So seems that the bolts on the CV joint have been changed out: Just happened to have H6 but only for a screwdriver that I cannot generate enough torque for… back to Amazon And I bet you won't find a gasket. Many people forget about them. Not sure how I feel about the change in bolts. Perhaps the hive mind will have some information in that. I suspect those original bolts were particular hardness etc. lots of forces involved there. I think I spy something living between the halves… |
emerygt350 |
Mar 21 2024, 07:56 AM
Advanced Member Group: Members Posts: 2,096 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Ouch. Transmission seal? That stuff looks pretty thick for 90w. Maybe the leftovers of a blown cv boot? Why wouldn't they clean it? Or is it still ripped?
trylon |
Mar 21 2024, 06:21 PM
Ouch. Transmission seal? That stuff looks pretty thick for 90w. Maybe the leftovers of a blown cv boot? Why wouldn't they clean it? Or is it still ripped? The boot is dry, and the CV gasket looks pretty intact— pre-sale inspection stated that both the engine and transmission leak. I bought it knowing that I would need to put more into it— I just forgot what haha! |
trylon |
Mar 21 2024, 07:20 PM
BillJ |
Mar 21 2024, 08:22 PM
Senior Member Group: Members Posts: 1,098 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
Isnt there a throughbolt for.the thermostat that if missing throws a bunch of oil?
emerygt350 |
Mar 22 2024, 04:23 AM
And you are going to want that tin eventually. Bellows can be had pretty cheap.
trylon |
Mar 22 2024, 06:27 AM
trylon |
Mar 22 2024, 06:32 AM
And you are going to want that tin eventually. Bellows can be had pretty cheap. Yes, I will be putting back all the missing bits eventually. The whole apparatus was missing on my Karmann Ghia, including the air intake ring. Put it all back in working order: https://youtu.be/sEt8SgzGHKw?si=z1A7n1pffmq4RQy2 |
FlacaProductions |
Mar 22 2024, 09:08 AM
Senior Member Group: Members Posts: 1,588 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
emerygt350 |
Mar 22 2024, 12:31 PM
And you are going to want that tin eventually. Bellows can be had pretty cheap. Yes, I will be putting back all the missing bits eventually. The whole apparatus was missing on my Karmann Ghia, including the air intake ring. Put it all back in working order: https://youtu.be/sEt8SgzGHKw?si=z1A7n1pffmq4RQy2 That's interesting. I didn't know they had their own style of air cut off. I saw a great Ghia the other day with one of those 0-60 (eventually) stickers on it. |
trylon |
Mar 24 2024, 03:54 PM
And you are going to want that tin eventually. Bellows can be had pretty cheap. Yes, I will be putting back all the missing bits eventually. The whole apparatus was missing on my Karmann Ghia, including the air intake ring. Put it all back in working order: https://youtu.be/sEt8SgzGHKw?si=z1A7n1pffmq4RQy2 That's interesting. I didn't know they had their own style of air cut off. I saw a great Ghia the other day with one of those 0-60 (eventually) stickers on it. I believe the lowlights had that intake ring, eventually went to flaps. |
trylon |
Mar 24 2024, 03:55 PM
Yes, where I got the Ghia one. If I recall, there are options. Hopefully it is clear what the 914 uses. |
trylon |
Mar 25 2024, 04:21 PM
emerygt350 |
Mar 25 2024, 04:47 PM
A 914 that doesn't leak oil makes me suspicious....
trylon |
Mar 26 2024, 08:35 AM
trylon |
Apr 4 2024, 01:27 PM
How many weeks does it take to change the oil?
Sounds like the beginning of a joke doesn’t it— you finish it because I am still changing the oil! Got the new drain plug that I carefully screened to make sure it would fit. It doesn’t. The plot thickens— it seems like someone else had the same problem and cobbled together a bolt that would fit, if rather poorly. Any insight into this would be greatly appreciated— leading a Porsche club coffee run on April 20 and it would probably be for the best if there was oil in the car. |
FlacaProductions |
Apr 4 2024, 03:24 PM
Interesting - i have that same LN drain plug - fits perfectly.
74 2.0 |
trylon |
Apr 4 2024, 06:34 PM
Lo-Fi Version | Time is now: 17th May 2024 - 02:19 PM |
