MD or DE eastern shore? Help needed w/ high idle : ( |
DC_neun_vierzehn |
Aug 10 2023, 02:15 PM
Member Group: Members Posts: 378 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
I have a '73 2.0 D-jet. Motor is fresh 2056 rebuild. I had amazing help from @Cupomeat re-installing the motor and trans back in Northern Virginia, but now the car is back with me in Rehoboth, Delaware. It's currently idling at 2,200 RPMs. Eric posted a thread trying to solve this while the car was still back in VA - the suggestions helped reduce the high idle from 3k to 2k, it didn't solve the issue. Thread here.
I've searched and read through countless posts here on 914 World trying to ID the problem, but no luck so far. Some of that could be on me (I'm still learning the D-Jet and working on motors in general). Is anybody nearby (I'm in Rehoboth, DE) that might be able to help ? I'm willing to drive to you. I recall seeing some members on the board being close , but I cannot recall who they were (someone was in Easton, MD another was in Annapolis, MD, another was in Georgetown, DE, etc.). Case of beer on me if you can help. (IMG:style_emoticons/default/beer3.gif) |
MDTerp |
Aug 10 2023, 04:23 PM
Member Group: Members Posts: 101 Joined: 20-May 08 From: Maryland Member No.: 9,075 Region Association: MidAtlantic Region |
@beatnavy is in Easton and he also has a 2056 with D-Jet.
BeatNavy |
Aug 10 2023, 05:48 PM
Yeah, Mike is right. I'm in Easton. I can probably help if you want to come this way sometime. I'm pretty flexible on time. I'll be in Rehobeth in September, but not with my tools (unless you count flip flops and cooler as "tools" (IMG:style_emoticons/default/smile.gif) ).
The thread link you posted didn't work for me. High idle is almost always a vacuum leak or sometimes idle too far advanced. |
brant |
Aug 10 2023, 07:07 PM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Double check timing
Spray carb cleaner for idle leaks Suspect a cracked plenum Idle screw??? |
DC_neun_vierzehn |
Aug 11 2023, 09:50 AM
Yeah, Mike is right. I'm in Easton. I can probably help if you want to come this way sometime. I'm pretty flexible on time. I'll be in Rehobeth in September, but not with my tools (unless you count flip flops and cooler as "tools" (IMG:style_emoticons/default/smile.gif) ). The thread link you posted didn't work for me. High idle is almost always a vacuum leak or sometimes idle too far advanced. Hyperlink fixed. Sorry about that. I will absolutely take you up on your offer to come your way (we can also link up when you're in town next month for a cold beverage if you'd like). I'll shoot you a PM to coordinate. Thank you. |
BeatNavy |
Aug 11 2023, 06:03 PM
PM responded to. Next week works (IMG:style_emoticons/default/beerchug.gif)
Geezer914 |
Aug 12 2023, 05:58 AM
Geezer914 Group: Members Posts: 1,415 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Do a smoke test to find the vacuum leak. I had a similar problem, intake flange was hung up on the engine tin causing a huge vacuum leak. Smoke test found the problem.
DC_neun_vierzehn |
Aug 16 2023, 08:49 PM
Had a lovely 80 minute drive from Rehoboth, DE to Easton, MD this morning to visit with @BeatNavy and troubleshoot my high idle.
Attached thumbnail(s) |
DC_neun_vierzehn |
Aug 16 2023, 09:04 PM
Watching Rob do his thing was a thing of beauty. Meticulously examining every possible culprit (pulling hoses, plugging hoses, checking/adjusting the timing, assessing valves, etc.) until he eventually found the issue: PCV valve hose was toast although not immediately evident. But I think the engine lid was open less than an hour.
I got lucky and he had a spare laying around. Problem solved. The ride back to Delaware was much nicer (and Waze took me down some back windy, shaded roads to avoid traffic, which was fun). Once again, I'm amazed by the knowledge, kindness and generosity of the 914 World Community. Would be lost without it. Thanks Rob. You're the best. Hope to see you in Rehoboth at some point in the near future. Still kicking myself for not getting a selfie of us in your garage before I left. I would have been smiling ear to ear in that pic! |
BeatNavy |
Aug 17 2023, 05:20 AM
Glad to help and to bond with another 914 owner.
Kris ( @DC_neun_vierzehn ) is a great guy and has a beautiful car (IMG:style_emoticons/default/beer.gif) |
rhodyguy |
Aug 17 2023, 06:18 AM
Nice job! (IMG:style_emoticons/default/smilie_pokal.gif)
MDTerp |
Aug 17 2023, 06:46 AM
This is awesome! Rob is very knowledgeable and always offering to help this community.
That hose doesn't look too old, was it cracked on the end? |
BeatNavy |
Aug 17 2023, 07:45 AM
This is awesome! Rob is very knowledgeable and always offering to help this community. That hose doesn't look too old, was it cracked on the end? Hey Mike! Yeah, it was cracked on the ends, and it was a little too short as well so it had the tendency to bend up at the fitting rather than giving a decent seal. It took a while to figure it out because it didn't look that bad, and I thought maybe the stacked elbow was bad. That, a small timing adjustment, and then adjusting air bypass screw and his idle settled in nicely. Kris did get the HE's/exhaust sorted beforehand and the car sounds and drives great (IMG:style_emoticons/default/driving.gif) |
MDTerp |
Aug 17 2023, 08:50 AM
Glad it worked out so well. I'm definitely going to check the ends of my hoses, because mine have some age but look good like that one.
DC_neun_vierzehn |
Aug 17 2023, 10:27 AM
StarBear |
Aug 17 2023, 12:37 PM
Senior Member Group: Members Posts: 1,885 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
We LOVE happy endings! (IMG:style_emoticons/default/beerchug.gif)
DC_neun_vierzehn |
Aug 17 2023, 01:21 PM
914_teener |
Aug 17 2023, 03:13 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Rob is a good guy...hey that' my name too!
He owes me a beer and glad he sorted your car. Rob: If you are ever in the AZ CA area shoot me a PM so I can collect my beer before the next Pandemic thing happens! The other Rob |
Lo-Fi Version | Time is now: 17th May 2024 - 03:44 PM |
