chris.t.10 |
Newbie ![]() Group: Members Posts: 6 Joined: 27-April 20 From: Los Angeles, CA Member No.: 24,189 Region Association: Southern California ![]() |
Hello! Im wondering if its possible to use a boxster transaxle with a 911 motor and/or my current 2.2l 4 cyl. Any advice? Thanks!
tygaboy |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,598 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California ![]() ![]() |
Boxster transaxles don't have a provision for mounting a starter so if you're looking to use an engine that doesn't mount the starter, you're on your own to modify the bell housing area and fabricate your own solution. It's been done but it's not trivial.
Subaru transaxles carry the starters so they may be an option. Kennedy Engineering makes adapters for many combinations so maybe check out their website and see if there's a combo that meets your needs. If cost is not the most important thing, they'll make you an adapter kit for almost any combination. Best of luck! |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,439 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Hello! Im wondering if its possible to use a boxster transaxle with a 911 motor and/or my current 2.2l 4 cyl. Any advice? Thanks! I have done it. It is NOT easy. You can read all about it here: http://www.914world.com/bbs2/index.php?showtopic=279084 I know there is one other air cooled 914 with a Boxster 5 speed in it. I saw it at Amelia Island in Florida. There are a few V-8 conversions with it. It is not so bad on a Chevy motor. |
Freezin 914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest ![]() ![]() |
Renegade hybrids is very knowledgeable about using Boxter transaxles on their builds.
Maybe check them out. |
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,829 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
Hello! Im wondering if its possible to use a boxster transaxle with a 911 motor and/or my current 2.2l 4 cyl. Any advice? Thanks! I have done it. It is NOT easy. You can read all about it here: http://www.914world.com/bbs2/index.php?showtopic=279084 I know there is one other air cooled 914 with a Boxster 5 speed in it. I saw it at Amelia Island in Florida. There are a few V-8 conversions with it. It is not so bad on a Chevy motor. Clay @ClayPerrine Which 914 was that? i dont remember seeing it was it a /6 or a /4? |
burton73 |
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,850 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
Renegade hybrids is very knowledgeable about using Boxter transaxles on their builds. Maybe check them out. I called and they say no. Not in there company model. but look at 6 speed boxster in a 914 with v8. look at 5.43 https://www.youtube.com/watch?v=6_geZF6_nKI&t=445s The shifting is so easy |
Lo-Fi Version | Time is now: 11th July 2025 - 12:18 AM |
