Routing air/fuel cable ? |
Literati914 |
Aug 20 2023, 08:50 PM
Senior Member Group: Members Posts: 1,461 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
What’s the preferred Routing of the air/fuel cable - do we like running it from the muffler, under the trunk and up thru the engine seal (to avoid some of the exhaust heat), or just going directly from the muffler under the car and engine compartment to the firewall?
My wiring harness is still out, and I can add (a portion of) the 02 cable to it, but need to figure out how long I need it to be, besides the question above. . |
windforfun |
Aug 21 2023, 02:15 PM
Senior Member Group: Members Posts: 1,789 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
TheCabinetmaker |
Aug 22 2023, 01:13 PM
Air/fuel cable?
Nogoodwithusernames |
Aug 22 2023, 01:54 PM
Member Group: Members Posts: 237 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
I would presume cable for an O2 sensor.
In my VW I ran it along with the rest of the engine harness. I don't have one in the 914, I would think it should be fine underneath the car until you can bring it up somewhere to join with some other part of the wiring harness for tidiness. I have not had issues with my wiring that is in the hot engine bay, only problem I have had is poor quality sensors going bad every so often. |
Literati914 |
Aug 22 2023, 02:14 PM
Air/fuel cable? (IMG:style_emoticons/default/lol-2.gif) Come on man, you know what I'm talkin' about! I'm not gonna insult until after I've got my lock situation in order .. then it's on! (IMG:style_emoticons/default/spank.gif) ..the cable (for the) wideband air/fuel sensor. . |
yeahmag |
Aug 22 2023, 02:21 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
At least with my Innovate LMO2, the connector is rather large. I created a new hole in the firewall (down by the shifter, below the cooling tin) and had a grommet to protect it. Ran it up along the center tunnel and to the device. I did cover it and the clutch cable in a protective, heat resistant sleave.
Lo-Fi Version | Time is now: 17th May 2024 - 06:49 PM |
