914 Transmission to speedometer drive O-ring, Contact for purchase of a 914 Transmission to speedometer drive O-ring |
Flying 914 |
Aug 24 2023, 05:47 PM
Newbie Group: Members Posts: 1 Joined: 3-April 22 From: Dallas, TX Member No.: 26,439 Region Association: Southwest Region |
I am looking to purchase a a 914 Transmission to speedometer drive O-ring as mine is leaking. Clay said someone on 914 world sells one that does not wear out/leak, could someone provide me the contact info for the person or company that sells these o rings?
David in Dallas. |
DRPHIL914 |
Aug 25 2023, 07:15 AM
I am looking to purchase a a 914 Transmission to speedometer drive O-ring as mine is leaking. Clay said someone on 914 world sells one that does not wear out/leak, could someone provide me the contact info for the person or company that sells these o rings? David in Dallas. @Flying914 check with www.914rubber.com Mark Whitesell makes the o rins and a better housing with 2 orings that helps stop that leaking. Phil edit: here is a link to this part with dual o-rings https://914rubber.com/speedometer-drive-gea...bushing-kit-1-1 |
ClayPerrine |
Aug 25 2023, 07:27 AM
I am looking to purchase a a 914 Transmission to speedometer drive O-ring as mine is leaking. Clay said someone on 914 world sells one that does not wear out/leak, could someone provide me the contact info for the person or company that sells these o rings? David in Dallas. @Flying914 check with www.914rubber.com Mark Whitesell makes the o rins and a better housing with 2 orings that helps stop that leaking. Phil edit: here is a link to this part with dual o-rings https://914rubber.com/speedometer-drive-gea...bushing-kit-1-1 I told David to post here and ask. I couldn't remember who made them, but I knew one of y'all would. Clay |
76-914 |
Aug 25 2023, 09:27 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,501 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
IIRC, 914rubber uses 2 different sizes on each drive. If they don't have one try @bdstone914 . If he doesn't have one PM me your address and I'll put one in the mail.
Lo-Fi Version | Time is now: 15th May 2024 - 01:45 PM |
