> Rear traling arm bushing selection
technicalninja
post Aug 27 2023, 09:27 PM
Post #21
I'm currently restoring the rear suspension on my 75 1.8l and wanted to get other's suggestions regarding rear bushings.
My shafts are fine and I'm planning on re-using them.
I already have a set of bushings.
Mine are the "Daystar" polygraphite set that you can get from multiple vendors.
These are in AutoAtlanta packaging.
These puppies fit stupid loose in the arms...
I worry about squeaking...
I don't like straight poly bushings for the most part.
Would you use them?
What grease would you use on them?
Normal silicon grease for urethane bushings?
914Rubber has a rubber set that are reasonable. $ 44
PMB and Elephant racing have rubber sets that are far more costly. $92, $240
This car will be a mildly upgraded streetcar for enjoyment not competition.
I'm leaning toward the 914Rubber set...
What says the hive mind?
technicalninja   Rear traling arm bushing selection   Aug 27 2023, 09:27 PM
DennisV   I'm currently restoring the rear suspension o...   Aug 27 2023, 09:44 PM
r_towle   Plastic bushings squeak. I have tried a few…they...   Aug 27 2023, 09:51 PM
technicalninja   Everything is apart and has been bead-blasted and ...   Aug 27 2023, 10:19 PM
yeahmag   I've used a bunch of different rear bearing/bu...   Aug 27 2023, 10:52 PM
JamesM   I've used a bunch of different rear bearing/b...   Aug 28 2023, 08:32 AM
mepstein   [quote name='yeahmag' post='3098453' date='Aug 27...   Aug 28 2023, 08:44 AM
Geezer914   Rubber bushings are fine for a street car to maint...   Aug 28 2023, 05:35 AM
Superhawk996   Ever stop and wonder why 99.99% of automotive OEMs...   Aug 28 2023, 07:08 AM
76-914   Ever stop and wonder why 99.99% of automotive OEM...   Aug 28 2023, 09:16 AM
technicalninja   I've used a bunch of different rear bearing/b...   Aug 28 2023, 07:54 AM
JamesM   A couple things to consider with ANY of the single...   Aug 28 2023, 08:50 AM
Superhawk996   Ding Ding - Winner :beer2: The 2nd issue to co...   Aug 28 2023, 12:00 PM
burton73   I couple things to consider with ANY of the singl...   Aug 28 2023, 02:16 PM
sechszylinder   I couple things to consider with ANY of the singl...   Aug 30 2023, 10:41 AM
Geezer914   I bought my 914 for spirited driving. My roads ar...   Aug 28 2023, 02:02 PM
ClayPerrine   I went through the whole delrin bushings and the n...   Aug 31 2023, 10:16 AM
Mikey914   Honestly, most folks wouldn’t be running enough ...   Aug 31 2023, 01:10 PM
mlindner   I've the poly/bronze for a almost not street l...   Aug 31 2023, 01:34 PM
914work   I went back to a set of Elephant rubber bushings. ...   Aug 31 2023, 03:05 PM
ClayPerrine   I went back to a set of Elephant rubber bushings....   Sep 1 2023, 03:54 AM
Superhawk996   Bottom line: pro driver on rubber bushings will s...   Aug 31 2023, 06:46 PM
technicalninja   Thanks for all the replies. I've decided to t...   Aug 31 2023, 06:48 PM
Matt Romanowski   I run Tangerine Racing bushings in the race car. T...   Sep 1 2023, 05:31 AM
- Lo-Fi Version Time is now: 11th July 2025 - 09:10 AM
