Name is Snick |
Newbie ![]() Group: Members Posts: 15 Joined: 28-August 23 From: NoVa Member No.: 27,550 Region Association: None ![]() |
This is on a 912E but I guess it’s the same on a 914.
Do I have to remove the Alternator pulley to get the fan belt off? The adjustment doesn’t seem to adjust far enough to get the belt off. Thanks |
Porschef |
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,180 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States ![]() ![]() |
Nope, should travel low enough on the adjuster to remove. Not a fun task, but it sure ain’t the worst. |
Van B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None ![]() ![]() |
Negative, just make sure the adjuster is loose, get a side started and work it around.
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,949 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
There is a bottom bolt that the alternator pivots on
Loosen that one also |
Name is Snick |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Sometimes a fat flathead screw driver on the alternator pulley resting on the outer surface of the pulley and under the belt.
Then rotate the pulley to move the screw driver further under the belt and the belt will pop off |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,360 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Worst case, you can unscrew the adjustor bolt completely (and catch the T-profile nut). That might let you rotate the alternator just a bit more.
Worst case, you can unscrew the adjustor bolt completely (and catch the T-profile nut). That might let you rotate the alternator just a bit more. (IMG:style_emoticons/default/agree.gif) |
Name is Snick |
Sometimes a fat flathead screw driver on the alternator pulley resting on the outer surface of the pulley and under the belt. Then rotate the pulley to move the screw driver further under the belt and the belt will pop off Doing the screw driver under the belt method requires that you have a way to turn the crankshaft/fan to advance the belt otherwise the belt doesn’t move. I can turn the alternator pully but the belt doesn’t move. Is there a tool to turn the crankshaft manually? Thanks for any help Snick |
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,880 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
Jack up one side, put it in 5th, roll a tire.
Since your engine is in backwards;), you should be able to get a socket on the crank too. |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,069 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Sometimes a fat flathead screw driver on the alternator pulley resting on the outer surface of the pulley and under the belt. Then rotate the pulley to move the screw driver further under the belt and the belt will pop off Doing the screw driver under the belt method requires that you have a way to turn the crankshaft/fan to advance the belt otherwise the belt doesn’t move. I can turn the alternator pully but the belt doesn’t move. Is there a tool to turn the crankshaft manually? Thanks for any help Snick (IMG:style_emoticons/default/welcome.png) Any or all of the above should get you there. Is the belt loose or cracked? is the alternator putting out |
Name is Snick |
Sometimes a fat flathead screw driver on the alternator pulley resting on the outer surface of the pulley and under the belt. Then rotate the pulley to move the screw driver further under the belt and the belt will pop off Doing the screw driver under the belt method requires that you have a way to turn the crankshaft/fan to advance the belt otherwise the belt doesn’t move. I can turn the alternator pully but the belt doesn’t move. Is there a tool to turn the crankshaft manually? Thanks for any help Snick (IMG:style_emoticons/default/welcome.png) Any or all of the above should get you there. Is the belt loose or cracked? is the alternator putting out trying to get belt off to run eng without alternator to see it the noise is alternator bearing noise or eng noise. Thanks |
Name is Snick |
Jack up one side, put it in 5th, roll a tire. Since your engine is in backwards;), you should be able to get a socket on the crank too. Hey, I like that! It's on two flat cinderblocks now. I'lll try to jack one side up without killing myself. But I now see this is a 2 man job, or one wife and one codger. thanks |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,816 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Jack up one side, put it in 5th, roll a tire. Since your engine is in backwards;), you should be able to get a socket on the crank too. Hey, I like that! It's on two flat cinderblocks now. I'lll try to jack one side up without killing myself. But I now see this is a 2 man job, or one wife and one codger. thanks It may be possible that the belt was too short when fitted ,perhaps worth checking when you get it off . |
930cabman |
I recently had a "locally rebuilt" alternator go bad with a resulting bunch of noise. Never took it back to Phil, but will soon as the /6 alternator needs inspection. Hopefully the noise is only in the alternator.
Front yard mechanic |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,321 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None ![]() ![]() |
Just drive it 90 mph trying to keep up @red rocks rally that belt will fly off by itself (IMG:style_emoticons/default/driving-girl.gif)
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,312 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
The belt is too short. A pocket knife will get it off. (IMG:style_emoticons/default/biggrin.gif)
Buy a new belt from one of our suppliers and experience joy and happiness. And welcome to 914World. We love the 912E too. |
Name is Snick |
Jack up one side, put it in 5th, roll a tire. Since your engine is in backwards;), you should be able to get a socket on the crank too. That 5th gear thing sounded good, so I tried it. I would need 3 men and a boy to rotate the tire. It won't budge. I like all of the well-thought-out suggestions. I like the 90 mph one. But my car won't go 90 mph. Any yes, I could cut the belt with a pocket knife, but I plan to put it back on unless I can get a new one. keep the suggestions coming. Maybe one will work. Thanks |
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,980 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
Jack up one side, put it in 5th, roll a tire. Since your engine is in backwards;), you should be able to get a socket on the crank too. That 5th gear thing sounded good, so I tried it. I would need 3 men and a boy to rotate the tire. It won't budge. I like all of the well-thought-out suggestions. I like the 90 mph one. But my car won't go 90 mph. Any yes, I could cut the belt with a pocket knife, but I plan to put it back on unless I can get a new one. keep the suggestions coming. Maybe one will work. Thanks Well it should have. Check you don’t have the e-brake on. If it is not moving I’d be looking for the reason why. |
Name is Snick |
Jack up one side, put it in 5th, roll a tire. Since your engine is in backwards;), you should be able to get a socket on the crank too. That 5th gear thing sounded good, so I tried it. I would need 3 men and a boy to rotate the tire. It won't budge. I like all of the well-thought-out suggestions. I like the 90 mph one. But my car won't go 90 mph. Any yes, I could cut the belt with a pocket knife, but I plan to put it back on unless I can get a new one. keep the suggestions coming. Maybe one will work. Thanks Well it should have. Check you don’t have the e-brake on. If it is not moving I’d be looking for the reason why. You were right. I tried again. It was very hard to get it to move at first. But I could move it an inch at a time after it moved. Just enough. The good news is the noise is not the engine, must be the alternator bearing Bad news is now I have to get alternator out. Do you know if you have to remove any tin? The bottom bolt is loose as is the adjuster bolt but I can't move the alternator. thanks |
Lo-Fi Version | Time is now: 9th May 2025 - 05:21 AM |
