door windows, inside fuzzy strips |
dgw |
Sep 5 2023, 10:56 PM
Dennis Winter Group: Members Posts: 553 Joined: 7-January 03 From: Santa Cruz Mountains Member No.: 106 Region Association: Northern California |
I have a 71 914. I know there is some kind of fuzzy strip in the inside of the window but I can't figure out what part I would order from either Pelican or 914rubber. Can anybody point me at the right part?
It looks something like this. I believe its a metal piece that attaches to the door with the pictured fuzzy strip attached to it. I could be wrong. |
Shivers |
Sep 6 2023, 06:19 AM
Senior Member Group: Members Posts: 2,373 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
If I’m remembering this right it is part of the door panel.
rhodyguy |
Sep 6 2023, 08:15 AM
You need to take off the inner panel. You will see some holes in the door on the top edge. The screws that hold the strip on are accessed thru the holes. More often then not the screws are rusted in place.
Rob-O |
Sep 6 2023, 09:24 AM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
As Kevin said. There is an aluminum piece that holds the fuzzy strip. The aluminum piece is held onto the door by (if I remember correctly) three screws. It’s difficult to see how to access those screws, if you can even see them at all. The holes in the aluminum to access the screws are hidden by the fuzzy strip. Look carefully along the fuzzy strip and you’ll see (or feel) the holes. Would t hurt to spray some PB Blaster or equivalent in there first. Given their location, they do have a tendency to get corroded, as mentioned above.
barefoot |
Sep 6 2023, 09:38 AM
Senior Member Group: Members Posts: 1,273 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Of all the fasteners I've removed from my 914, those 3 tiny screws were the ONLY ones I could not get out, good luck trying.
dr914@autoatlanta.com |
Sep 6 2023, 10:26 AM
914 Guru Group: Members Posts: 7,857 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we have plenty plenty of them in stock both NEW and good used ones
I have a 71 914. I know there is some kind of fuzzy strip in the inside of the window but I can't figure out what part I would order from either Pelican or 914rubber. Can anybody point me at the right part? It looks something like this. I believe its a metal piece that attaches to the door with the pictured fuzzy strip attached to it. I could be wrong. |
914werke |
Sep 6 2023, 10:54 AM
"I got blisters on me fingers" Group: Members Posts: 10,059 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I have a 71 914. I know there is some kind of fuzzy strip in the inside of the window but I can't figure out what part I would order from either Pelican or 914rubber. Can anybody point me at the right part? It looks something like this. I believe its a metal piece that attaches to the door with the pictured fuzzy strip attached to it. I could be wrong. As mentioned there is a aluminum rail that holds that fuzzy strip in place & they are different early to late. The three screws are accessed through the door frame via three holes at the top edge. Don't bother with available aftermarket fuzzies they don't seem to fit. Buy the OE unit but be prepared the are kinda pricey. |
Mikey914 |
Sep 7 2023, 09:47 AM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Here is a picture and link to the entire kit. You may not need all of it but you can see what the parts are.
You are looking at the top of the inner door fuzzy closest to the driver. There are several parts to look at while you are there, the kit takes care of most of them. https://914rubber.com/early-door-window-kit-for-914 Do note the window buttons, as it’s a great time to change them out. The only other thing as a while you are there item would be the door cam actuator. (IMG:style_emoticons/default/biggrin.gif) Attached thumbnail(s) |
Root_Werks |
Sep 7 2023, 10:06 AM
Village Idiot Group: Members Posts: 8,319 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I bought inner and outer fuzzies from 914Rubber. They installed fine.
If you are not painting your 914, I wouldn't try to remove the outer aluminum rail. Just remove the old fuzzy, really clean out the channel and install new. 50% of the time the 3 little screws need drilled out = PITA. -Dan |
76-914 |
Sep 7 2023, 10:21 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,501 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I've been able to come in on the backside of those frozen screws and back them out with a pair of needle nose vice grips or side cutters. There is only about 5-6mm of thread that protrudes out. The window will need to be up and you'll need to be a bit of a contortionist. I've only needed to drill out one but then again I'm in SoCal and not the Rust Belt. (IMG:style_emoticons/default/biggrin.gif)
dgw |
Sep 7 2023, 11:18 PM
Time to terminate this thread. I thought the metal piece and fuzzy was on the inside of the window, but I wasn't sure and was trying to figure it out before I bought the bits. It turns out that the metal piece and fuzzy is on the outside of the window and the inside piece, which is what is missing on my car, is much simpler. The missing inside pieces should be arriving Saturday from 914rubber.
dgw |
Sep 7 2023, 11:21 PM
delete duplicate.
Lo-Fi Version | Time is now: 15th May 2024 - 12:52 PM |
